Old 06-29-2006, 04:33 PM
GregB GregB is offline
Differential Lubricant - 96 Z28
I need to change the differential gasket on my 1996 Z-28. Naturally, I will also drain and replace the lubricant, however, I cannot find anywhere in my Haynes manual where it tells me the type of lubricant to use. Can anyone tell me what type of differential lubricant to use?
Thanks,
Greg
Old 06-29-2006, 05:16 PM
Re: Differential Lubricant - 96 Z28
I guess I should have read the owner's manual prior to posting my first messgage. I read it, and it gave me the type of lubricant, however, the type of lubricant depends on the type of differential - regular or limited slip. So now my question is, can anyone tell me how to tell if I have a regular or limited slip differential?
Thanks,
Greg
Old 06-29-2006, 06:57 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
you have LSD. not reg..assuming its the original.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 06-29-2006, 07:09 PM
It is the original. Thanks
Greg
