Old 06-29-2006, 01:01 PM
RallyFanatic's Avatar
RallyFanatic RallyFanatic is offline
Does oven cleaner dissolve putty?
Just wondering, I need to repaint a model which has received a lot of putty work (both basic Tamiya and Milliput) and I was wondering: if I put it in oven cleaner, will it not only dissolve the paint but also dissolve the putty?
Does anybody have any experience with this?
Projects: DAF Turbotwin X1, Escort Cosworth, Tamiya 206+Fujimi Cooper=Mini WRC.
I'm slow.
Old 06-29-2006, 01:39 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Does oven cleaner dissolve putty?
Best way to do it is sand the paint down.
-Mike
Old 06-29-2006, 01:43 PM
It is the underside of the car, so sanding is nearly impossible. I thought oven cleaner would work nicely, I just don't feel like puttying and sanding again
I'm slow.
Old 06-29-2006, 02:22 PM
ZoomZoomMX-5's Avatar
Yes, oven cleaner generally will dissolve putty along with paint.
What type of paint is it? If it's acrylic you might get away w/an alcohol bath or window cleaner; that shouldn't affect the putty or plastic.
If it's Tamiya TS it might come off w/alcohol (99% isopropyl rubbing alcohol) w/o affecting the putty.
What's harder, sanding what you have or stripping and re-puttying?
My Fotki Album
Old 06-29-2006, 02:32 PM
Monster_20 Monster_20 is offline
I just finished a similar project. I used 99% isopropyl rubbing alcohol and the putty (Tamiya 2-mix-to-1 type) turned out "OK". It still ate into where the putty is thin (like edges) but nothing major. The amount of work was similar to preparing a resin kit.
Old 06-29-2006, 09:52 PM
weaponCIVIC's Avatar
weaponCIVIC weaponCIVIC is offline
how about brake fluid?
http://www.automotiveforums.com/vbul...d.php?t=620111
"Look as far as the eye can see, go there, then look farther."
Old 06-30-2006, 11:41 AM
drnitrus's Avatar
drnitrus drnitrus is offline
I know csc eats tamiya basic grey putty and im pretty sure it ate millliput for me once too.
Old 06-30-2006, 11:49 AM
mike@af's Avatar
Brake fluid dissolves putty.
-Mike
