Old 06-29-2006, 11:12 AM
Bassasasin Bassasasin is offline
94' Park Ultra Water PUMP
Wow what a job..
94' 130k mi. Ultra
My water pump broke apart. The GM part flange to shaft unwelded and the pulley flew off to take out my belts and they burned a hole in my power steering pump's plastic secondary resovoir.
2 belts $60
1 water pump $22
1 power steering pump $72 (epoxied it.. -$72)
Coolant $7
Power steering fluid $5
MY Total Damages.. $166 In parts.
Took me 6 hours and a six pack. All from the topside.
Remove = (R)
R Battery + terminal
Drain coolant. (to later get heater hoses out of the way)
Support engine with jack and board.
R Right motor mount completely. (just loosen lower bolts on fender) .
Jack Lift motor further carefully with board on oil pan.
R Cross over strut support (makes it easier)
R Serpantine belts
R Alternator completely (makes it easier)
R Coolant Resovoir (makes it easier)
R Dual Idler wheel
R Loose Power steering pump push it back for bolts access.
R Heater hose tubes. (pop out)
R Loose Aux support (Gen, Power steering) aluminum frame and push it back
Just about now you can get to that one bolt under the Power steering/Alt support frame.
R Water pump
Reverse to replace.
Not really bad but.. most cars are a little easier.
Old 06-29-2006, 04:09 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 94' Park Ultra Water PUMP
Originally Posted by bassasasom
2 belts $60
1 water pump $22
Coolant $7
A quiet afternnon with beer, wrenching and creating new cusses............
Priceless.
Old 06-29-2006, 10:27 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Priceless.
Hehe...that sounds so familiar. 'Cept mountain dew instead of Beer...I'm underage...and I think beer is kinda nasty.
I'm so happy that my series I mounts to the lower subframe instead of the inner fender brace in the engine bay
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 06-30-2006, 07:38 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Beer is perfect for soothing the mind and soul during a tedious, time-consuming project such as, say, a HEATER CORE! Job well done, bassasasom, you saved another $166+++ in labor charges!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
