Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 06-29-2006, 07:05 AM
Oprava Oprava is offline
Drop in rpm
I have Chrysler LeBaron 4-door 1994, 3L V6 MPI, 4sAT. Over the last couple of months, once in a while when idling, the engine rpm drops to zero and then quickly returns back to about 600 rpm and continues to run. Recently, however, on two occasions when such a drop in rpm occured engine stopped running. I restarted and continued. Something is happening or about going to happen. How can I prevent it or fix it? Thanks for the advice.
Old 06-29-2006, 01:26 PM
94LebConv3La604 94LebConv3La604 is offline
Re: Drop in rpm
When was the last time your fuel filter was changed? Definitely sounds like a fuel supply problem.
Old 06-30-2006, 06:17 AM
Re: Drop in rpm
The filter was replaced about a year ago. But I will do it again. Thanks.
Old 06-30-2006, 03:36 PM
Re: Drop in rpm
Fuel filter should be changed every 6 months or so...but even a year shouldn't cause that unless you have a lot of sediment in the gas tank...and only if you let the tank get low before filling up again.
Old 07-23-2006, 10:13 AM
drgreenthumb drgreenthumb is offline
Re: Drop in rpm
I'm not sure if its the same, but my lebaron 2.5L turbo has a target idle of about 912 rpm. Mabe your timing is retarted and its struggling?
Old 07-24-2006, 12:12 PM
GBH1's Avatar
GBH1 GBH1 is offline
Re: Drop in rpm
hello I had that same problem once at it turned out to be that one of the spark plug wires was messed up, so you can try checking that.
Not I - I won't conform to what I see in you, Not I - I won't surrender what I am, Not I - And even if it was a part of me, Not I - I'll never be that way again- Demon Hunter
