Old 06-29-2006, 04:23 AM
kyuuketsuki kyuuketsuki is offline
Question acrylic plastic
hey guys,
i've read about scratchbuilding in forums, and modellers use styrene sheets. Can styrene be replaced by acrylic plastics instead? Any idea? My area, acrylics are more readily available then styrene and cheaper.
Why is styrene used and not acrylics then?
Old 06-29-2006, 06:23 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: acrylic plastic
Originally Posted by kyuuketsuki
hey guys,
IMHO, I would say: flexability. I'm not sure what thicknesses you can get in acrylics but styrene comes in various thicknesses. IE: 1.2mm, 0.5mm, 0.3mm, 0.2mm etc. I've only seen arcrylics in 8.0mm, 5.0mm and 3.0mm... not really the most suitable for modeling, unless you are making something in 1:6 or 1:4...
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 06-29-2006, 09:10 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: acrylic plastic
Acrylics arent as flexible or workable as styrene sheet from what I have experienced.
-Mike
Old 06-29-2006, 10:39 AM
Re: acrylic plastic
one other side question. "white glue" is this the regular school glue, the one that is literally white in colour and not clear like tamiya cement clear?
Old 06-29-2006, 10:56 AM
bhop73's Avatar
bhop73 bhop73 is offline
Re: acrylic plastic
yes
http://www.bhop73.com/
Old 06-29-2006, 09:54 PM
Re: acrylic plastic
great.. that we have in my country. finally... something available..
thanks!
Old 06-30-2006, 12:10 AM
bhop73's Avatar
Re: acrylic plastic
Were you planning to use 'white glue' for model building? If so, it won't be strong enough for plastics. It's more for glueing paper, although many people use it on clear parts to avoid hazing, but I wouldn't recommend it for most modeling purposes.
Old 06-30-2006, 03:57 AM
Re: acrylic plastic
yeah, on clear parts. hmm what do you recommend then, for clear parts and what do you recommend for for plastic parts. I am aware tamiya or other modelling cement melts the plastics...
Old 06-30-2006, 08:26 AM
mike@af's Avatar
Re: acrylic plastic
You want to use a cement on plastic parts, because it melts the plastics together. Just make sure you dont use it on clear parts.
-Mike
Old 06-30-2006, 10:58 AM
bhop73's Avatar
Re: acrylic plastic
As GTmike400 said, you want to use the 'melts the plastics' type of glue. It provides a stronger bond. Just use it sparingly and you shouldn't have a visible melting issue.
Glues I personally use are Testors Model Master liquid cement. This comes in a black plastic sort of triangle-ish shaped container with a long needle shaped metal tip for easy application. I also use CA glue (super glue) if i need a fast strong bond, specifically Zap-A-Gap brand. I have also used Plastiweld, but i'm not a huge fan of it.
Old 06-30-2006, 03:43 PM
Re: acrylic plastic
erm, so on clear parts it is still advisable to use white glue?
i dont want to 'spoil' the clear parts on my about-to-start suzuki kit.
thanks
Old 06-30-2006, 05:27 PM
bhop73's Avatar
Re: acrylic plastic
If you're gluing some small parts, it should be fine. There is also "canopy glue" that airplane guys use that seems to be a good choice. I haven't used it so I don't know much about it though...although, I think I will buy some. If it works out, maybe i'll post a review about it.
http://zap.supergluecorp.com/pt56.html
