Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-29-2006, 02:45 AM
92gm 92gm is offline
Question Brake Lights/Dash light problem
My brake lights and my dash lights won't turn on when the headlights are on. The brakes will turn on sometimes during the day. Also, when the headlights are on they will sometimes turn off for a second or two then turn back on. I assume it's a wiring problem. Is there anyway I could get a free wiring diagram or would they even have them in the books? It's a 92.
Old 06-30-2006, 01:49 PM
KimMG KimMG is offline
AF - Advisor
Re: Brake Lights/Dash light problem
Haynes manuals sell new for about $20-. There are many sources for used copies (ebay, amazon, etc). Free info maybe available at your local public library, online from library and school websites (need a library card or student ID number). www.autozone.com has free repair guides available with some wiring diagrams.
Do the tailights work? Look for a loose or corroded plug around the steering column. Check for bad ground wires.
Old 06-30-2006, 02:09 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
On a lot of the Ford style headlight switches, the connector on the back of switch will melt causing a loss of connection. I am assuming the brake lights you are talking about are the tail lights. Check what KimMG has suggested and the headlight switch and connector.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-30-2006, 07:34 PM
Well the tail lights yes, when I go in reverse the white tail lights in the middle will turn on but that's about it. My blinkers will also work. Thank you for the suggestions, I'll have to try them.
Old 06-30-2006, 07:43 PM
AF - Advisor
I'm confused. Which lights are having the problems? Back-up lights? Tail lights? Brake lights? Rear turn signals? Rear marker lights? Front marker lights? Front turn signals? Low-beam headlights? High-beam headlights? Dash lights? Dome light?
Old 06-30-2006, 08:07 PM
way2old's Avatar
TOKEN HILLBILLY
Have you checked all the fuses? Sems like there are a lot of lights out for one part being bad.
Old 06-30-2006, 08:26 PM
my dash lights...and brake lights, as in, when I push on my brakes, the lights don't work.
