Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 06-28-2006, 10:30 PM
robbie_NH robbie_NH is offline
96 sedan loose door panels
I just bought a '96 with just 53K miles and it first seemed in great condition. But now that I own it, both front interior door panels are loose, the wood-grain trim pieces are loose and appear to have their mounting tabs broken plus the left door panel is actually cracking in half ahead of the switch panel. Is this a common problem or was the poor car abused? Are replacements available new or used?
Old 06-29-2006, 12:10 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 96 sedan loose door panels
The problem with the loose door panels could be broken or weak door panel retainers. These are plastic and hold the panel to the door. I suspect that maybe someone attempted to repair the window slides, which can break and are a common problem with the GM B- body cars from 91-96. I just replaced the slides in both my front doors and rear drivers side door. When I went to remove the panel, I broke a few of these clips, and noticed that a few others were broken even before I attempted this repair. It appeared that whomever tried to fix the window previously did a sloppy job and slapped everything back together. The clips are GM part # 15600382 and are about .45 each. They are sold by the dealer in a bag of 20, and each door panel uses 5 clips. It is a fairly easy job to do to replace the clips. There is a special tool you can get at the auto parts store to aid in removing the door panels. My left panel is also cracked in the area you describe. Again, it appears to be the result of a rushed job to either remove or put back on the door panel. I started looking around for replacement panels with little luck, but I know something like this takes time. My friend also has a '96, and HIS panel is cracked in the same location. One site I found when I Googled "door panels for 1995 Roadmaster" listed requests from other owners of Roadmasters looking for the same panels. There must have been 30 or more requests from Canada and the US. Funny thing is most of the requests were for panels in maroon color. Mine and my friend's are saddle/tan. While my friend was helping me relace the window slides, he commented on how the panel. clips and trim were broken and how this must have resulted from an inexperienced mechanic or owner attempting to do the job, or they were in a hurry and didn't care.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 06-30-2006, 12:46 AM
ilgoldstein's Avatar
ilgoldstein ilgoldstein is offline
My 95 Sedan has a loose door panel, makes a bit of noise. I can see looking in from the side of the door that there is a clip attached with part of the plastic broken off, too far to reach in. Anyone have luck repairing these? Seems a shame such a great car has such poor door panels.
I just turn the radio up or rest my leg on the panel!
1995 Buick Roadmaster Sedan
1989 Cadillac Sedan De Ville
1964 Chevrovet Malibu SS
Old 06-30-2006, 01:34 PM
Those plastic clips are pretty cheap at the dealer. I paid around .45 for each one. Kind of makes it not worthwhile to try and fix an old one. I actually got mine at our local Chevrolet dealer, ( same parts as in the Chevy Caprice of the same years, 91-96.) I listed the part number for the clips in my previous post. I'm wondering if all this damage we see on these door panels could be caused by inexperienced employees at the body/repair shops the previous owners took them to, or the previous owners themselves who attempted repairs on the door components,(power window motor, window clips, power door lock apparatus, etc.) My friend and I took our time to get the door panels off to do the repair on the window clips, and even then we broke a few of the door panel clips in the process. We even used the special tool for removing the door panels. Some shops may not bother to replace the broken clips because either they don't have the replacement clips on hand or don't want to go the extra step to replace them, hoping the owner will not notice .
Old 06-30-2006, 02:09 PM
Just reread my post, I was unclear. The clip is find, nice and tight. It has a chunk of door panel attached that is no longer part of the door panel!
Old 06-30-2006, 11:51 PM
I wonder if the chunk of door panel could be separated from the clip and re-glued to the door panel? Sounds logical, but I don't know if it was tried how long the repair would last. Another option would be to take it to a business that specializes in auto interiors or restorations and get an estimate. maybe they would have more experience at a repair such as this, and quite possibly may have even done some in the past successfully. It may be worth a try.
Old 07-01-2006, 11:12 AM
I haven't pulled it off and probably won't until I need to. I was thinking that if there was enough room, pop riviting a metal plate to hold it in place. If there is room, maybe a plate on either side.
Meantime, I'll just rest my leg against it when it rattles too much!
Old 07-08-2006, 12:19 AM
buffman buffman is offline
Crazy glue, hot glue and or expoxy work good for reattaching clip retainers to the door panels. it's too bad eventually since the door panel design sucks, they're just going to break again
Old 07-08-2006, 11:49 AM
That's probably why the clips are so cheap at the dealer,(under .50 each).
Old 07-09-2006, 07:26 PM
The real shame is the lack of reasonably priced replacments. I can get replacements for my 64 Malibu for something like 125 a pair.
Maybe in 25 years our cars will be collectors and there will be more restoration parts. Then again ................
Old 07-09-2006, 10:25 PM
I was thinking the exact same thing a couple of weeks ago. I have stacks of catalogs for interior parts for my '64 Bel Air, but cannot find any aftermarket or OEM parts catalogs for interior parts for the Roadmaster. Maybe our cars are too young to have replacement parts available. I thought I read somewhere awhile back where GM sells the rights to reproduce parts for some of their vehicles after a certain amount of time has elapsed. Meanwhile I troll the internet salvage yards, my local ones, including classified ads, and will once in awhile check out Hemmings Motor news. Hopefully persistence will pay off sooner rather than later.
Old 07-14-2006, 03:38 PM
Kgilljr Kgilljr is offline
Well, I'd like to add my loose and broken panels to the count. My RH panel is loose and the LH panel is loose and broken as previously described. But, my leg is not long enough to rest against the RH panel. Ken
Old 07-15-2006, 12:12 AM
But when all is said and done, I wouldn't trade my Roadie with it's loose door panel for a Park Avenue with a plastic intake manifold, a late model Impala with disposable brake rotors, or a Ford, any Ford (although the new Mustang is tempting!)
Guess we are just stuck with a rattle for the next 300,000 miles.
Old 07-15-2006, 12:51 PM
Old 07-16-2006, 06:33 AM
silverfox103 silverfox103 is offline
Hi
Unfortunately, the door panels are poorly designed. I own 2 Roadmaster Station Wagons. What I have found is the clip holder on the panel usually breaks and if the panel is loose it will end up getting destroyed. I know from experience. The front panels have the most problems. Good used panels are hard to find.
What I ended up doing was using self tapping screws to secure the panel to the door. Sometimes you can hide the screws for example I have used the "pouch" to screw into. Make sure there is metal behind where you are drilling.
Just last week, I checked both wagons, and secured any loose spots.
Good Luck
Tom C.
Littleton, NH
