Old 06-28-2006, 09:35 PM
camaromaniac camaromaniac is offline
question about air dams
i bought an air dam, got it today, went to put it on, and saw that it only left me with about three inches of ground clearence! i dont wanna take a chance with my $25 ending up on the road somewhere, so if i cut some off of the bottom of it, will it still function properly?
Originally Posted by Rally Sport 92
Dont get me wrong though i'd love a Lt1 in my Camaro even if it had Richard Simmons strapped onto my hood naked..
Old 06-28-2006, 09:37 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: question about air dams
I don't see why not, it's just there to help uplift the air to the radiator. Shouldn't make too much of a difference if it's shortened in height a little bit.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 06-29-2006, 12:29 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
what piece exactly are we talking about. It its the large black plastic piece under the radiator then I dont understand why you would be willing to cut it but dont want it rubbing on the ground. they are supposed to be low
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 06-29-2006, 10:10 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Yeah, air dams will hang low and will scrape on the road sometimes it's almost unavoidable. I wouldn't cut it unless it seems to hit all the time. Plus you have to consider that they are made out of pretty flexible plastic as long as you fasten it to the car well it won't be coming off it'll just bend a little when it scrapes.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-29-2006, 01:49 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
yuup mine is all scraped and scrapes on my driveway.. sometimes it scares me and i think its scraping my front nose.. but yeah.. it'll flex and wont come off as long as its fastened properly.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 06-29-2006, 01:50 PM
oh yeah.. you can see mine in the picture on my sig..
Old 06-29-2006, 04:04 PM
skyluslondon's Avatar
skyluslondon skyluslondon is offline
just fasten it the best possible, dont get cheap on the bolts. mine only scrapes on obvious stuff. coming out of inclined driveways...bad parking lots. ya know. all you can do is go as slow as possible. if it scrapes it scrapes, they can take a lot more than you think and dont break very easily.
Old 06-29-2006, 09:15 PM
CamaroRS92 CamaroRS92 is offline
I did some measurements tonight and the air dam on a 3rd gen. has 3 7/8 inches of clearance from the bottom edge to the floor.
I wouldn't worry about breaking the air dam - they are tuff as heck and will stand up to the scraping.
I would think that if you break one off, then you are in a place that a camaro has no business being anyway and you are likely going to also tear off your front spoiler or at least do some damage to it. ( and after that you prolly should check for a hole in the oil pan- )
Old 06-29-2006, 09:45 PM
i put mine up to the bottom of the radiator yesterday, and there was only about 2 inches clearance. i think that might be because i need new struts, but im about to replace those. as of now, it hangs down much farther than the front spoiler, and i do live on a completely horrible road that has potholes that can be 2 inches deep. plus, with speed bumps it would definately scrape. i just keep hearing from other people how easily they fall off, and didnt want to take a chance with mine.
Old 06-29-2006, 11:09 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Completely falling off? Thts the first of that i've heard about.. as long as you tighten it good the thing wont fall off.. the only way it can come off is if it cracks/rips off.. it has happend to my Monte's when I accedently went up on the curb and came back down on the otherside.. so it cracked, but the thing is really durable because on my Camaro, it's scraped many times even before I got it because its bend back a bit..
Cutting it wasnt the way to go
Old 06-30-2006, 10:39 PM
abojangles abojangles is offline
I am having a problem with my car heating up idleing and even driveing down the road the thermostat is working and the water pump is cycleing but it still gets up in the mid 200's. Do the fans only run when you are in traffis or when i am going down the road.
Old 07-01-2006, 10:45 AM
Blue Bowtie's Avatar
Registered Offender
Tighten it? It's held on by plastic push-pin rivets. AFAIK, there is no way to "tighten" those.
http://www.thirdgen.org/techboard/cooling
Old 07-01-2006, 11:05 AM
The front ground effect / spoiler is attached with push pin rivets but the air dam is bolted on
Old 07-01-2006, 02:52 PM
Is eating.
This is normal if your Camaro/Firebird is a third gen (82-92) they were made by design to be hot. It in turn causes stuff to go out quicker (Starter for one) if you'd like it to run cooler you can buy a 160 Degree thermostat, but I hope you dont live in the colder states or it can become a problem during the winter.
