Old 06-28-2006, 09:20 PM
Bigblockjoe68 Bigblockjoe68 is offline
1979 Trans Am engine swap
i have a 79 TA with a boat anchor 301. Would like to swap it for a better powerplant. Can a chevy small block be used? Or would it be better to use a Pontiace 400 or 455? Are the motor mounts the same? Is it compatible with my borg warner 4speed tranny? Could I also use the existing brackets for the alternator and power steering? What headers could I use? Any help would be greatly appreciated. This TA needs a heart transplant!
Old 06-29-2006, 01:24 AM
Morley Morley is offline
Re: 1979 Trans Am engine swap
A 79 T/A with the 301? Never heard of that, the engines offered in the T/A for that year were the Olds 403 and Pontiac 400. You sure it is really a T/A and not a Formula or Esprit with the T/A hood and badges?
The 301 was the only "small block" Pontiac ever made and I don't know if it shared the same bellhousing bolt pattern as the rest of the poncho's (which won't bolt up to a chevy engine)
If it is a true T/A, I'd look for the "correct" engine for it (check the VIN), either the 403 or 400
Old 06-29-2006, 10:41 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Yeah, what Morley said...
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-29-2006, 06:52 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
yeah, that's an odd combo for a 1979 TA , i would go with a 400.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 06-30-2006, 12:02 AM
79Bandit's Avatar
79Bandit 79Bandit is offline
400 the only way to go..more relaible than the 455 and great potential
Old 07-01-2006, 08:09 AM
They also offered a 301 and a 301 turbo. These motors are boat anchors with tons of smog chit. Does anyone know of a pontiac 400 crate motor?
Old 07-02-2006, 09:21 PM
The 301 Turbo was offered in 1980 and in 1981 the turbo was dropped, you only got a N/A 301.
Old 07-07-2006, 01:35 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
do a google or yahoo search
first hit for me:
http://proformanceunlimited.com/pontiac.html
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
