Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-28-2006, 08:03 PM
djawmolfe djawmolfe is offline
Exclamation oil in water
I just got a 95 lumina APV 3800 with what was believed to be a rear head gasket failure but now im starting to wonder. It was leaking coolant badly from the back of the block and also there was a little oil in the water but no moisture in the oil. After I pulled the alt. I found a plastic fitting for a water line on the block broken (must be the cause of the water leak). My question being can oil get into the water from just a LIM gasket failure or should I just replace all of it since i'm already there? Thanks
Devon in MI
Old 06-28-2006, 09:00 PM
LMP's Avatar
LMP LMP is offline
Re: oil in water
Are you sure the oil in hte water is motor oil? There have been reported cases of transmission oil leaking through the radiator cooler...otherwise lower intake manifold gasket failure is a known occurrence with the 3800. Head gasket failures are very rare on the 3800.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 06-29-2006, 06:46 AM
Re: oil in water
OK mabye I wont go as far as the head gasket - the engine runs great but the previous owner told me alot of oil was leaking off the back of the block, but I believe it was oil in the water leaking from that bypass hose fitting. Will it be obvious when I pull the intake if its the culprit? And is there a way to test that radiator? Thanks
Devon MI
Old 06-29-2006, 07:12 AM
LMP's Avatar
LMP LMP is offline
Re: oil in water
A head gasket failure would be accompanied by several or all of these symptoms: fluctuating temp indicator, overheating, poor heater performance and steam venting the radiator. As for the transmission cooler and LIM gasket I have not experienced those but I know loosing coolant from the back of the engine is a classic symptom. Others will surely come in this thread and comment. More have talked about this in the Bonneville forum...but there are more occurrences with the series 2 3800..
http://www.automotiveforums.com/vbul...d.php?t=283650
which I am not sure if it was actually used in the Transport/APV following its introduction in 1995 in other GM cars...1995 was the last year the 3800 was used in the Transport/APV
If you dare disconnecting the cooler lines from the radiator.....I'd block one port and use compressed air in the other to see if bubbles come through the coolant from the top of the radiator......The suggestion about the radiatior is "do not forget to check that out also, just in case"....; although this event has been reported, I see that as a low probability..unless you have already determined the "oil" was transmission type...
Old 06-29-2006, 11:12 AM
Re: oil in water
Well, ill start digging into it tonight after I get home from work. Looked on car-parts.com and found a radiator locally for $50. I hope thats the problem so I dont have to start tearing into the engine.
Old 06-29-2006, 02:50 PM
Re: oil in water
Wll I just got homw and relised that I have tranny lines and what appears to be oil lines running to the radiator. I cant tell if the oil in the radiator is from the tranny or engine.
Old 07-01-2006, 09:40 AM
LMP's Avatar
LMP LMP is offline
Re: oil in water
There are no motor oil lines to or around the radiator. But there are lines from the power steering that go to a loop of piping tied to the lower frame just under the radiator.
Old 07-01-2006, 12:49 PM
Re: oil in water
I see that now -- trans cooler on both sides.
