transmission questions???
I married into the ownership of a 2000 malibu 3100 with automatic tranny. The car has almost 80k miles on it. I want to service the tranny and I am trying to figure out a couple things. The car seems to be in good shape and I want to prolong the life of it. If switching to synthetic fluid for the tranny what would be recommended? How much should it cost at a shop to do a complete flush? How much fluid should I buy to give the shop for the flush? I am thinking of royal purple max atf fluid. Let me know what yall think... Thanks
Re: transmission questions???
I agree with not doing the flush, just drop the pan, change the filter and add 7.5 quarts of any regular or synthetic Dex 3 trans oil. I did notice much smoother shifting with Amsoil ATF.
Why not flush??? It doesn't make sense to me why you only replace part of the fluid just to be contaminated with the old fluid in the system...
In another vehicle, I had my fluid flushed at about 95K miles. At 107K I had to replace my tranny.
I agree not to flush also.My father knows a guy who owns his own transmission shop that cleans valve bodies out after finding out the person had the transmission flushed after getting a complaint like this:does not shift right.The transmission shifts fine after a valve body cleaning with a fluid and filter service.I had to replace a transmission also that was acting up after being flushed.
Your transmission has a goofy set to check the transmission fluid level.It has no dipstick and there is a plug near the passenger axle,transmission side to remove.It is a lengthy procedure.
OK... I have drained the fluid and removed the pan from the tranny this afternoon. I left it apart to drain overnight. Tomorrow I will change the filter and put it all back together. I have two questions... Where exactly is the filter and how to change it. The other question is how to check the amount after adding the fluid... When I checked the level b4 draining I had the car running and nothing seeped out of the check screw hole. I cycled thru the gears and nothing. When I shut down the motor a bunch of fluid drained out of the hole. Why is this and what is proper way of using the check screw hole?
Car must be level. Engine running and in park. Fluid temp 104 deg F, 5 minutes idling should do that. With pan drop start with 7.5 qts, the new Dexron VI is out now. After filling and fluid proper temp remove plug and if no fluid comes out add until it does, if it just dribbles it’s full. If you wait it will keep dribbling because the fluid is getting hotter and expanding. Put plug back before shutting off engine LOL. The big black thing you see is the filter, just pull it off. |
Thanks for the response everyone. I finished the job this afternoon. I tell ya, it is not a hard thing to do but it sure is messy and a pita. It took right at 8qts to fill back up. I had a friend pour the last 2 qts while I was under car watching the check screw. Once it started dribbling I capped it and told him to stop pouring. This seemed to work well. I am sure not all the fluid had settled but it could not be much over the plug if any. Thanks again for the help. Oh... How much old fluid is left in when doing this type drain and filter?
A dry transmission takes about 13 qts.
OK, how do you decharge the A/C so I can replace the radiator? I have a leak into the trans and need to replace the radiator, and do a trans flush..
Thanks.
