Old 06-28-2006, 06:08 PM
Scottm69s Scottm69s is offline
Carbon in EGR Valve
I just replaced my EGR Valve last week in my 95 Blazer. Just yesterday it started sputtering again like it was before the replacement. I took it in and they said carbon is getting into the EGR valve and it will continue to get in it until it is all cleaned out. Has anyone else had this problem? They said take off the upper intake and clean the passage out and for them to do it they want $180 - "ya right". Do they mean the air intake? Anyway any help is greatly appreciated.
Old 06-28-2006, 06:17 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Carbon in EGR Valve
Find a egr valve gasket with the screen made in it.
Tomco and other aftermarket parts co make them.
All of the engines around that year go threw the old carbon ball making deal.
No big deal just screen the egr valve gasket and live with it.
And when you have the egr valve off start the engine up and let some of it blow out of there.
Most engine will quite that bad habit in time or later on.
Good luck
MT
MT
Old 06-30-2006, 09:22 AM
sirfej sirfej is offline
I just replaced my EGR valve in my ’95 Blazer too. I’ve been using a Tomco gasket with the screen for about the last 20k or so, but I think the EGR was due to be replaced anyway. It was original and had 119k on it. I had cleaned it several times, but it still seemed to stick, so I got a new one from Advance Auto Parts for like $125.
Anyway, it runs pretty good now, but still idles rough and the exhaust smells sort of rich and a bit like rotten eggs. I am wondering if I have messed up the CAT or possibly need to replace something to do with the fuel injection?
I should also note that it has been hard to start for the last six months and the new EGR hasn’t helped this noticeably. You have to crank on it a while before it will finally fire. Also, there is a good amount of black carbon in the tail pipe – looks like the same carbon that was building up in the EGR valve.
There was a code set about a month ago too. It related to the EGR valve, so that’s another reason why I replaced it. I have already done a tune up prior to all of this. If anyone has other suggestions, please post them.
Thanks.
Old 06-30-2006, 09:56 AM
MT-2500's Avatar
AF - Advisor
Thanks.
Welcome to your first post on AF
Sounds like you may have more problems.
But it would be better to start a new tread or post on it and post the year and all info you have and some one will help you.
MT
MT
Old 06-30-2006, 01:25 PM
leadalto leadalto is offline
Thanks.
Your problems seem a lot like the ones I had with my 93 S-10 Blazer several months ago. Replacing the "spider" and "nut kit" fixed the black carbon coming out of the tail pipe (also had an EGR code set but I only cleaned the EGR valve). This did not fix my no start/hard start problem. To fix that problem, I had to drop the tank and replace the fuel pump.
Old 06-30-2006, 02:31 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
if the cpi is bad, excess fuel in the exhaust will mess up the cat (mine started to rattle after cpi/nut kit replacement).
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 06-30-2006, 03:13 PM
THANKS FOR THE HELP MT-2500. I am on the Tomco site know and that looks like it might work or it is at least my best shot. Even the mechanic that looked at my truck didn't know about this. You guys rock.
Old 06-30-2006, 03:17 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
The screen in there is a life saver on that problem.
Get the gasket no and check your local parts places.
Most of them now have them.
Good luck MT
MT
Old 06-30-2006, 06:21 PM
I was lucky in that I did not put on too many miles with soot coming out of the tailpipe. Probably not more than 20 miles. After replacing the fuel injection and fuel pump I passed the California smog test without replacing the CAT or the EGR valve (or the O2 sensor but that's another thread).
One thing I replaced that didn't need to be done was the starter switch. I was sure that the hard starting was due to the switch. On my 93, replacing the switch was a super PITA because it was very difficult to get both tools and hands together into the limited access space.
Old 07-06-2006, 11:24 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
cpi and nut kit will need replacing.
I also don't like using the screened gaskets seeing it just keep the carbon in the plenum where it doesn't belong, you want the carbon out of there.
The carbon is there because of the cpi and nut kit leaking. You should fix that to stop the cause.
The screened gasket is just a bandaid.
Since my cpi and nut kit replacement I no longer have any carbon and I don't have a screened gasket.
With the screened gasket, the carbon pieces will collect which will hinder the EGR flow over time which will cause pinging due to the inappropriate amount of EGR gas being able to get into the combustion chamber where it is needed.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-06-2006, 11:53 AM
MT-2500's Avatar
AF - Advisor
BlazerLT
That might be hard to do on the ones that do not have a nut kit.
MT
MT
Old 07-09-2006, 04:41 PM
BlazerLT's Avatar
AF -Advisor
Originally Posted by MT-2500
BlazerLT
MT
We are talking about a 1995 right?
Only 95's that have problems with carbon in the EGR is the CPI motor with a nut kit.
Old 07-09-2006, 06:14 PM
MT-2500's Avatar
AF - Advisor
BlazerLT
The poster did not say what engine he had.
3 different 4.3 V6 that year.
You may be right if it is a CPI.
But 95 had both PCM and VCM W engine codes and also the Z computer systems.
In 1996 they went to he fuel lines going into the top of intake.
MT
MT
Old 07-09-2006, 09:13 PM
BlazerLT's Avatar
AF -Advisor
Yip and both VCM and PCM engines were CPI engines and from what I have heard and seen, almost no 1995 Blazers came with the Z motor, most if not all had the W CPI motor which had carbon and EGR problems due to a defective nut kit or CPI injector regulator.
Old 07-10-2006, 03:50 PM
MT-2500's Avatar
AF - Advisor
BlazerLT looks like you have been doing a little home work. On the 95 4.3 V6.
Carbon ball codes in the old EGR valve are Kinda like a 02 sensor codes.
Do not throw parts at it untill you check it out.
Proper testing would be in order. Could be the nut kit or cpi injector unit or one of many other things.
I thing for sure the screen in the egr valve gasket will save a lot of removing and reinstalling the erg valve untill the problem is found.
MT
MT
