Old 06-28-2006, 03:25 PM
kennie616 kennie616 is offline
Thumbs down turn signal...
hi.. i just had to replace my ignition switch harness because of the common ac problem that makes the ac not work on 1-4 settings and i got that fixed and everything works except the turn signals dont work on either side and its not the fuses because i checked those... should i take back to the pontiac dealership and have them look at it>? i think it might be a problem with the connectors or something
Old 06-28-2006, 05:02 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: turn signal...
Take it back to the stealership before it is too late. If they were working before then it sounds like they screwed the ignition switch job up. I recall there is a connector and wire connections that feed the multifunction switch (turn signals).
Timeslip 08/12/06
AF Community Guidelines
Old 06-29-2006, 05:58 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: turn signal...
I agree Bob., take the car back where you had it worked on Kennie616
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
