Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-28-2006, 02:05 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Backfire
Hey all;
Ever since I installed my ported TB the car has been back firing... The main time it does it is when I downshift. I rev match and punch it into gear and it'll back fire every now and then. It also did it earlier today when I pulled out of a gas station really quick bc of traffic. As I was about to shift to 2nd, it back fired. Plugs, wires, and coil pack are good. I've checked. It's been doing it since I put the TB on for sure. It was fine before that. Only happened maybe once a month or so. Any ideas here?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-28-2006, 02:12 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Backfire
well you have to be running pretty damn rich to backfire. You probably have a vac leak somewhere on your throttle body. Air is getting out. Have you checked all the vacuum connections?
now - 2000 civic
soon - 2002 is300
Old 06-28-2006, 02:19 PM
david-b's Avatar
Dave is THAT guy
Re: Backfire
I've checked but I can't find any leaks. When I'm driving I hear a hiss, sounds like a turbo, and I can hear it get higher as the rpms rise and IM pressure goes up.
75 Monte Carlo
Old 06-28-2006, 03:23 PM
Re: Backfire
yep you have a leak somewhere. Try putting some soapy water in a spray bottle and spray it all over your throttle body. It will bubble if there is a leak. Do this while the car is running. If you still can't find it, built a boost leak tester, heh.
now - 2000 civic
soon - 2002 is300
Old 06-28-2006, 03:29 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Backfire
Ha ha, boost leak tester on a NT car...
Maybe a shitty gasket? Did you put in a new one with the new TB? Did you torque er down good?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-28-2006, 10:11 PM
david-b's Avatar
Dave is THAT guy
Re: Backfire
I got a new gasket when I did the TB. I didn't torque to specs, but that SOB is on there good. I'll try the soapy water thing when I get a chance.
So, what is the science of this? Why would a leak at the TB cause it to backfire?
75 Monte Carlo
Old 06-28-2006, 10:19 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Backfire
If you crank it down instead of torquing it to the spec then you'll ruin the gasket and get a nasty leak...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 06-28-2006, 10:35 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Backfire
you could have put hte gasket in backwards...mechanic that did my TB and diagnosed my bad idle was cause i installed the tb gasket backwards.. all in all a new TB fixed it lol
Old 06-28-2006, 10:43 PM
david-b's Avatar
Dave is THAT guy
Re: Backfire
You cant on the 420a. It only fits one way. It has such an odd shape design to it.
75 Monte Carlo
Old 06-28-2006, 11:29 PM
Thor06's Avatar
Jizzed In My Pants
Re: Backfire
I dont exactly know what I am talking about but its the only thing that makes sense to me. Back firing happens when there is a lot of extra fuel and not all of it burns and gets into the exhaust manifold where it then combusts. Well, the only way you would be getting a lot of extra fuel is by some of your air leaking off, hence the "nonturbo boost leak". I dont know if I am right, but like I said thats what makes sense to me.
