Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-28-2006, 02:01 PM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
I Added To The K&n Fipk...4.7 Wj
Ok, I have been reading what people had to say about the FIPK. Is it worth it or not? I think so.. Some ppl believe that the FIPK is sucking in alot of hot air versus the stock set-up. I agree with that.. All you have is the heat shield provided..Not good enough...So heres what I just did...
I went to Home Depot and picked me a roll of aluminum flashing. 20"X10' for $11.. I redrilled the holes in the heat shield in order to raise it up 1" so that the weather stripping on the heat shield makes alot better contact with hood when closed...It seals it off better ...I think thats what they intended in the first place but who knows...
After redrilling and reinstalling heat shield I started cutting the aluminum into smaller pieces..I ended up using 2 pieces and screwed them together after forming them into the right shape...I then screwed the aluminum and heat shield together... Kind of made a full wrap around version of the heat shield and with the hood making better contact with the weather stripping on the heat shield I would say its pretty much enclosed...I drove around for a while and got the engine up to running temp stopped popped the hood and touched the aluminum and it was only warm to the touch...
I think that means I am keeping the air a little cooler at the filter...right?
What I think I have done is kinda made it enclosed just like the factory set up all the way through...just not airtight...I also reinstalled the piece that directs air from grill to filter and its pushing the air right to the K&N filter...
Then I painted it black and it looks pretty good....
Any Thoughts
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
Old 06-28-2006, 09:39 PM
bringselpup's Avatar
bringselpup bringselpup is offline
Re: I Added To The K&n Fipk...4.7 Wj
I think we need a pic.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 06-28-2006, 09:53 PM
jeepgclwj's Avatar
Old 06-28-2006, 09:54 PM
jeepgclwj's Avatar
jeepgclwj's Avatar
Old 06-28-2006, 09:55 PM
jeepgclwj's Avatar
Old 06-28-2006, 09:57 PM
jeepgclwj's Avatar
Sorry about all the posts. I'm an idiot...
Old 06-29-2006, 12:21 AM
Purple_Haze Purple_Haze is offline
well, dont say that, just post the pic
Old 07-05-2006, 04:05 PM
post your pic from some other website, that does not require anyone to have Microsoft Passport login. It's fu**ing annoying ... i get that login screen 5 times when i click on your post.
photobucket.com or something else.
