Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 06-28-2006, 11:20 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
2003 trans fluid change
dose anyone know how to check trans fluid level since this trand has no dip stick? almost 50,000 miles and i want to change trans fluid & filter.
Old 06-29-2006, 02:18 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: 2003 trans fluid change
it's non servicable. you haave to take it in to get it worked on. my grandfathers malibu was the same way...he traded it in because of that.
Old 07-02-2006, 05:33 PM
dbirkey dbirkey is offline
I discovered there is a check plug on the transmission. Look on the right hand side of the transmission where the drive shaft goes out to the right wheel. It is located about 3 inches above the pan & sits under the final drive. Initially fill till fluid comes out. Then start car & fill again till fluid comes out. Recheck when the transmission is fully warm. Good luck.
