Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-28-2006, 10:48 AM
RWK RWK is offline
1997 aurora starts then dies.
Here Is The Issue I Have A 1997 Aurora It Has Been Dying It First Started Dying As Soon As You Put It In Reverse And Gave It Gas To Back Out Then It Started Dying Went Put In Drive Now It Starts Ocassionallyshoots Out A Blue Spark And Dies And Won't Start Again.
This Is What We Have Changed On It
Spark Plugs
Spark Plug Wires
Ignition Coil Module
All The Coil Packs
Pass Key Module
CrankShaft Sensor
Old 06-28-2006, 03:41 PM
baron1701 baron1701 is offline
Re: 1997 aurora starts then dies.
Have You Had It Scanned For Codes? If Not, Bring It Into An Autozone Or Advanced Auto And Get Some Codes.
Old 06-29-2006, 10:40 AM
RWK RWK is offline
We Have Scanned It For Codes When It Was Running Wrote Them Down.i Will Have To Find The Codes The Car Is Not Running Right Now So I Can't Take It To Auto Zone. I Know One Of The Codes Had To Do With The Crank Shaft Sensor Not Sure About The Other Codes I Know It Had Three Come Up.
Old 06-29-2006, 12:28 PM
The Crank Shaft Position Sensor Will Certainly Cause Major Issues With Keeping The Car Running. I Would Look Into Replacing The Two. The Blue Spark Thing Still Has Me Confused. Where Is The Spark Coming From?
Old 07-15-2006, 07:44 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
also on the opposite side of the intake there is a "blow out" valve and the oring around that could be bad.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
