Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-28-2006, 07:15 AM
FreshBubble FreshBubble is offline
Low Oil Level
Ok, so I have this problem with my car. My low oil level light comes on sometimes when I start the car. But the thing is, the gauge on the dash that shows your oil level is around the same area it usually is, and it isnt going past the red line. Also, if I drive around for a little bit, and turn off the car and then turn it back on, the light wont come on. Does anyone know why its doing this?
1994 Chevrolet Caprice Classic 4.3L
Old 06-28-2006, 10:11 AM
GreyGoose006 GreyGoose006 is offline
Re: Low Oil Level
idk, but if it were my car, i would check the oil level at the dipstick
Old 07-01-2006, 11:05 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Low Oil Level
could be malfunctioning sender unit
could be wires chafed at sender,
among other things
visual inspection plus testing is how to find out
also dash warnign lights odnt always come back on a bit after shutting off the car
really random most times, but if the car has sat for a really long while then all the warning lamps should light with ignition on but engine off
if not then bad senders or bad bulbs
if your oil level is fine and it runs good and doesnt use oil then i wouldnt worry much about it, and would instead worry more about tires and brakes and such more important things
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 07-01-2006, 06:20 PM
Blue Bowtie's Avatar
Registered Offender
Re: Low Oil Level
I'm with the Goose - Use the dipstic to check the crankcase oil level. It's been foolproof for over 100 years. If the dipstick shows correct level, the next time you change you oil, plan on removing the level sensor and cleaning it. It's fairly easy:
Incidentally, the gauge on the dash does not indicate oil level. It indicates oil pressure. Pressure can be normal even if the level is two quarts or more below full.
Old 07-02-2006, 10:00 AM
Re: Low Oil Level
Yea, I checked the dipstick and I needed to add some oil. Only thing is, I dont think my car is leaking oil. I park it in my driveway and I never see any oil on my driveway.
Old 07-02-2006, 12:39 PM
Registered Offender
Re: Low Oil Level
If the oil level is decreasing, and there are no apparent leaks, there's only one place it can be going - Out the exhaust.
BTW - Did topping off the oil to satisfy the dipstick also satisfy the switch?
