Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 06-28-2006, 12:27 AM
cyruslam cyruslam is offline
Great power loss...............
two days ago, my sol have done a oil flush and oil change (also the oil filter).
after that i found my sol have loss a lot of power than before.
when i startt the car, the rev stay at about 600, then when i accelerate (gear1), very slow.
and i change gear and accelerate harder, the rev does go up a lot, and then drop back after a few seconds, but the speed didnt increase much.
what would be the problem? clutch? engine? spark?? anyway that i could checK and how?
Also if 15w-40 and 5w-40 both were added to the engine (e.g half half), will that cause any problem?
Old 06-28-2006, 08:22 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Great power loss...............
You NEVER want to mix oil viscosities. and BOTH of those are too heavy for your car. Between those two things being done wrong, your motor is probably moving very sluggishly. 15w40 is like sludge. I run 10w50 in my car, but only during race season. The proper motor oil weight for a honda is 5w30. If you got your oil changed somewhere, bring it back, tell them to do it with 5w30 and ONLY 5w30, and tell them they best be doin it for free. I would also check your oil filter to make sure it's tight enough. Then either open your oil cap or pull off the valve cover to see how everything under there looks. If they're covered in oil too thick you can be on your way to some trouble.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
