Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-27-2006, 09:48 PM
jeffbeck jeffbeck is offline
Unhappy 94 gcl sputtering issue
This just started happening a few months ago. The truck drives like it's got bad gas or water in the line. It happens at any speed whether I'm idle at a stop or doing 80, it's as if somebody's turning the fuel injection on and off. Spark plugs still look new, but I get the check engine light on from time to time which I had checked by pep boys, and they told me it's the 02 sensor.
I'm no mechanic, but I doubt the 02 sensor would be causing this problem.
Anybody have any thoughts?
Old 06-28-2006, 11:53 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 94 gcl sputtering issue
Could be the crankshaft position sensor. Do a search here and in the Cherokee forums.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-29-2006, 09:21 PM
any way to verify that it's the crank sensor if it's not comming up as an error code?
Old 06-30-2006, 07:31 AM
Not that I know of, but I'm not one of the good electronics guys. You've got a distributor on the '94, right? How are your cap, rotor and wires? That could cause an issue also and is worth a check.
Old 06-30-2006, 06:39 PM
I don't know the first thing about checking the rotor or distributer, do you mean the wires going to the spark plugs?
Old 07-02-2006, 05:50 AM
Yes, that's part of it. If you trace the plug wires (which may themselves be part of the problem) back from the plugs, they should all go to a common point. This point is the distributor cap. Inside the distributor cap is the rotor, which turns and "distributes" spark to the cylinders in turn. When you take the cap off, look at the contacts inside. They're probably very dirty and kind of "fuzzy" from all the electrical contact. Replacements should be on the order of $20 or less, and you can get a good set of plug wires for a little more.
Make sure that when you are changing them, to do them one wire at a time so as not to get them mixed up.
Of course this might not be your problem, but this could be contributing factors, since you're not getting any codes.
