Old 06-27-2006, 09:31 AM
mambo77 mambo77 is offline
Changing Fuel Filter '89 Le Sabre
I haven't had the fuel filter changed in about 3 years and want to try doing it myself.
I'd appreciate any info about location, etc in order to do it properly.
Many thanks!
Mambo77
Old 06-27-2006, 01:08 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Changing Fuel Filter '89 Le Sabre
It is on the drivers side, under the rear portion of the rear door.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 07-01-2006, 08:37 PM
Greig8's Avatar
Greig8 Greig8 is offline
Send a message via ICQ to Greig8
The fuel fitler on my '90 at 82800 miles has never been changed. I bought one the other day but I havn't changed it yet becase I couldn't find the relay to the fuel pump to depressurize the system. I unplugged one relay but after running the car for several minutes it never stalled out like the book said it would. Where is this relay and how long should the car run after it's unplugged? or is there another way to depressurize the system?
Old 07-01-2006, 11:11 PM
Alibi's Avatar
Umm...relay? Funky...
All I ever do is undo the gas cap and engage the schrader valve on the fuel lines to the engine. By depressing the schrader valve you effectively relieve fuel pressure in the lines. Much easier then looking for a relay...Actually, I think the fuel pump is controlled by a fuse located in the relay center behind the glovebox.
-Eric
