Old 06-26-2006, 11:16 PM
Jergin01's Avatar
Jergin01 Jergin01 is offline
Unhappy Suspension help...
I took my car to get looked at a while ago, but they found "nothing wrong." Well I hear a grinding noise every time I turn the steering wheel to the right. It grinds on a slight rights and hard rights, so I think there might be a problem. The mechanic said it was my 20" wheels rubbing but I see no signs of it rubbing. I don't know what to check for or to look at and I really don’t want to drive the car without having an idea of what's going on. Please help...
2000 S-10 Blazer LT 4.3L EFI 4DR 4WD
Alpine CDA-9835 Headunit w/ iPod
Custom Wheels w/ Toyo 255/40/20
Custom Exhaust - 3" Chrome Outlet
All Clear Lights w/ L.E.D Bulbs
Silver Interior w/ Brushed Aluminum Trim Pieces
Check out my Blazer on CarDomain.com
http://www.cardomain.com/ride/856449
Old 06-26-2006, 11:54 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Re: Suspension help...
could be a bad wheel bearing, if it's only when you turn right check the drivers side, when the load from the weight transfer hits it, thats when you'll really hear it. But if it is that then you should (but not always) hear a moan at a highway speed as well.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 06-27-2006, 12:03 AM
Jergin01's Avatar
I do hear it at highway speeds. How do I go about checking that?
Old 06-27-2006, 01:56 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I have the same thing, push your rotor dust shields back.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-27-2006, 11:23 AM
Jergin01's Avatar
The dust shields are behind the rotors correct? And whats the easies way to do that?
Old 06-27-2006, 11:59 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Grab them with your fingers and tug them away from the inside rotor face. I had a Dodge pickup that would collect stones between this plate and rotor when off-roading and deep mudding. Would make the most horrible noise. Jumping out of the truck into a dry spot, I could wedge gloved fingers slightly behind the plate by the edge and tug on it. Out would fall a few rocks and she'd be good to go again.
Old 06-27-2006, 10:01 PM
BlazinMlew's Avatar
If by chance it is that and something is stuck in there, then check the back sides of your rotors as well. Chances are that it would tear it up and put a nice grove in the rotor making it a little unsafe.
Old 06-27-2006, 11:00 PM
BlazerLT's Avatar
AF -Advisor
Yes, just put your thunmb on the 5 and 7 o'clock position and push they back firmly.
Old 06-29-2006, 12:13 PM
Jergin01's Avatar
Thanks, one more question my brakes squeak sometimes when the car is moving but stop if I apply a little pressure to the brakes? How do you fix this? So many little things need to be done to this thing!
Old 06-29-2006, 01:10 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Pull the pads and spread a thick layer of Anti-Squeal on the back of them. Typically it's orange or red goop. You can find it available at most parts stores.
Old 06-29-2006, 01:51 PM
wolfox's Avatar
Yep, yep, what Rlith said. Also, use a good synthetic caliper grease on the slide pins that hold the caliper in place on the hubs and you'll be golden.
Old 06-29-2006, 02:12 PM
BlazerLT's Avatar
AF -Advisor
Your pads could be almost wearing out and you are hearing the indicators rubbing the rotor saying they need replacement.
Old 07-03-2006, 05:53 AM
rlith's Avatar
Jergin, did you find your solution?
Old 07-04-2006, 10:17 PM
jd-autotech jd-autotech is offline
if its a trail blazer there is a known problem with the right front axle seal if not i would be after the the sheilds behind the rotors
