Overrevving 700R4s?
In normal drive, the automatic transmission makes the drive kinda boring, but in the D gear right under drive, it's easier to peel out and the rpms hit higher. Is it bad to constantly drive it in this gear(Overdrive)?
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
Re: Overrevving 700R4s?
I think all that gear (if I understand correctly) is your 3rd gear. By not having the transmission in the overdrive gear, your just not letting your tranny shift to 4th gear. So basically, the highest gear your driving in is 3rd, not 4th. I think in 4 speed autos, 3rd is the 1:1 with 4th being the overdrive.
To try and answer your question, if your running high RPM's most of the time, yes it can be bad. And you'll also get worse gas mileage, because your not using your overdrive. |
Alright now I'm just confused. the normal drive IS overdrive?
![]() Quote:
If I were you, i'd use the regular D for when you want to peel out or go a bit faster but then use the overdrive for when you're just cruising..
What I tend to do, when I get on the highway, and I like to get quick to 60 mph, but what I do is shift it down to D, get up to 60 (Or higher, depending on traffic) and then switch it off to overdrive..
I notice no one said anything about gear 1 or 2. Since those are my lowest ratios, those should give me the most power but I shouldn't try it should I?
You would have to be absolutely sure where your rpm will be if your going to drop to 1st or 2nd. If your tv cable is adjusted properly you should be fine for downshifting automatically, especially if its just in drive and not overdrive. Your trans has 3 gears only. Much like a th350 except the 700r4 has converter lockup or overdrive which when engaged drops the ratio to 1:1 for highway mileage. So the 700r4 has 3 gears and then the converter lockup, or 4 speeds. When you put it in just D it prevents the converter from locking. This makes the converter heat up which makes your trans heat up. NOT good to just ride around with it in D. for a quick boost it probably wont hurt anything. If your going to do it a lot its best to get a trans cooler. It could make the difference in the end. Just make sure your tv cable it set right.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
better a clutch pack than a pushrod...although I dont know if you can mechanically over rev with an auto...Your shifting is more or less controlled by a pressure spring in the tailshaft of your trans(anybody correct me if im wrong on this) so in normal conditions it shouldnt let you downshift to early. Your stock motor is going to blow before the trans will though. You have to get a torque converter rated at higher rpms if you want to go reving very high.
Knew a guy with a forged 383 that he was reving out to 7000 rpm on stock 700r4's. He was also changing them out once a month but he was pumping almost 500rear horse through them and launching on 315 DR's...obviously the man was crazy but it worked for him. Nice car...point is your going to blow your motor before your going to have to worry about the trans...
That all depends on build date of the car. In '87 GM addressed issues with the 700 not holding up. If it's one of the cheesy ones.......
![]() ultimately there's a check to prevent excessive pressure from going to a lower gear and causei over revving. in most situations. |
Like if your driveshaft or u joint breaks while your launching....bad things....
Sorry but wrong. Overdrive is a gear with a less than 1:1 ratio, I woulda thought you know that. The 700r4 and 4l60e have 4 gears.. the ratios being 3.06, 1.63, 1.00, and 0.70
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
hmmm......poo.....i have been duped.....i must go to my room of shame.....
Could swore that it was that way....CRAP!!! now im pissed!......
http://www.gearvendors.com/hrgm4s.html
http://www.s10v8.com/viewtopic.php?forum=5&topic=13049 now that im thoroughly confused......splain lucy... i believe you are right but I was convinced that it only had 3 hard gears.... ...i am not worthy....
It has 2 reduction gears (3.06:1 and 1.63:1), 1 equal gear (1:1), and 1 overdrive (.70:1). Sorry, not quite sure what your confused about.
