Tranny Removal 97 gtp
Anybody have detailed instuctions on how to remove a GTP Tranny?
Re: Tranny Removal 97 gtp
loosen lug nuts, remove cv axle nuts (34mm i think, its been a while)
jack up front of car remove tires disconnect cooler lines from radiator remove trany pan and drain all fluid (less mess afterward) put trany pan back on place a wooden block between jack and pan or prefably use a trany jack remove the air filter housing and disconnect hose from throttle body remove bolts around bell-housing i belive 8 (i think) 18mm bolts, they got one stubborn bolt that you can only get to by coming behind the engine from the passenger side remove the starter (make sure the battery disconnected) remove the torque convertor bolts (i think 3 of them) to get to each bolt you have to turn the flywheel, i used a pry bar **it helps to take off the brakes and rotors** remove the cotterkeys from the a-frame bolt, and take out the nuts disconnect the sway bar (i think 13mm) knock the a-frame loose by hitting the side with a hammer remove the cv axles remove the trany mount on the passenger side (2x 13mm bolts i think) disconnect the speed sensor disconnect the other harnesses on the driver side and pop off the gear select cable unbolt the sub-frame on the driver side (i think 15mm bolt) pull the trany out from the driver side fenderwell ^^im sure i left out something but thats basically it this is assuming a 4t60e trany, if your replacing it make sure you keep the side cover pan, the gear selector link (one 10mm bolt) and the lower pan incase you damage the new one installing it also... if your going to rebuild the trany, i'd recommend going with a shift kit and an aftermarket cooler... they pay for themselves in time
sry mods i'll try 2 b good
i just remembered you got to remove the dip stick its a 10mm bolt
^^^ not bad pulled some before? I don't do anything with the brakes, starter or the sway bar. just my 2cents~ they are 15MM nuts for the tranny mount and dont for get the engine mount nuts they are 15MM. what are you using to support the engine?
Troy
i've pulled a few, i seem to have bad luck with the 4t60e tranys i replaced one in a 95 grand prix, 95 beretta, 97 cutlass, all 3.1s i wouldn't imagine the 3.8 would be much different since its the same trany
you don't have to completely remove the brakes, just take the caliper off and pull the rotor off, it makes it easier to get the cv axle out since you don't have to bend it as much, extra stress isin't good i also remove the sway bar for less stress for engine support... im out of ideas
Decipha
Thanks for the detailed instructions. If I remember right you do have to have the engine supported when you remove the cradle. |
