Old 06-26-2006, 05:41 PM
jonphelps1976 jonphelps1976 is offline
2000 5.3L z71 whining noise
I have a 2000 silverado 5.3 with 140k on engine and 60k on tranny. Engine whines upon acceleration. I thought this might be a tranny problem but I also hear the noise when the truck in in park or neutral. Anytime I increase the acceleration I hear the whining noise. The more acceleration, the louder and higher the pitch becomes. Any ideas where to start?
Thanks.
Old 06-26-2006, 06:53 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 2000 5.3L z71 whining noise
Thanks.
Lots of possibilities here, for starters take off the serp. belt, see if the noise goes away, if so look for a noisey alternator, idler or tensioner pulley bearing.
Old 06-26-2006, 07:17 PM
The sound definately appears to be coming from the area of the serpentine belt. I could not isolate it but it was near the alt.
Any suggestions on what the most common malfunction would be?
Also, is the noise in the belt and tension or is it possible that the alt could actually be making that noise?
Old 06-27-2006, 08:49 PM
lftdblksilvy33 lftdblksilvy33 is offline
hey. i was just about to ask the same question on my truck. i got about 90k miles and this past week, its done it 3 times, but not consistenly... it sounds like its coming from the transmission as well, but i can't figure out the problem. it whines one acceleration, and usually after 1st or 2nd gear it goes away... any ideas?
Old 09-13-2007, 10:55 AM
markz71 markz71 is offline
may be your low on blinker fluid
Old 09-13-2007, 11:27 AM
weo38 weo38 is offline
Ha Ha Ha good one, blinker fluid I'll have to remember that one. It could be the bearing in the altenator for the pulley. As to going away after shifting from second could definitely be from the tranny.
2009 Z-71 ECSB
2007 Yamaha Grizzly 700 FI
Old 09-13-2007, 01:28 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Check your belt.. you may need a new belt tensioner
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 09-15-2007, 04:20 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
You have to be careful here...some guys might try to add to it and use the wrong stuff...
Old 09-15-2007, 05:32 PM
knogoodidleft knogoodidleft is offline
Yeah, and I would higly recommend flushing out the halogen and getting some silvania cool blue.
Old 09-18-2007, 09:27 AM
rocksjesse rocksjesse is offline
bearing spun on a/c maybe?
