Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-26-2006, 04:44 PM
lowwered lowwered is offline
cooling problem
hey there i need some help i have a 1990 eclipse and i have changed the head gasket and the water pump and put in a new rad and it is still overheating if the car i at idle its ok but when i give it gas it pushes it out the overflow what is wrong need help thanks Les [email protected] email me if you can help thanks............
Old 06-26-2006, 06:50 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: cooling problem
How do you know it is overheating? As the pressure in the coolant builds up, it's supposed to empty a little into the overflow tank. That's what it's there for.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-26-2006, 07:16 PM
EricSchnabel EricSchnabel is offline
Re: cooling problem
That is normal when it cools it will suck some back in.
Old 06-26-2006, 08:31 PM
Re: cooling problem
hey man what is happening is that when i let it idle its ok but when i give it gas it pushes all the rad fluild into the overflow and then over heats thats what the problem is
Old 06-26-2006, 08:37 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: cooling problem
try burping the system.
While the car is cold, take the radiator cap off. Squeeze the upper radiator pipe as hard as you can so the fluid almost flows over. Do this for a few minutes and it should get an air bubble out if you do have one. Make sure you have enough fluid too!
now - 2000 civic
soon - 2002 is300
Old 06-26-2006, 09:35 PM
Re: cooling problem
i have tried that to i filled the rad from the upper rad hose until it came out of the thermo houseing i even ran the car with the heat on full and it never goes past half temp but the problem is that when i give it gas it pushes all the fluid out of the overflow i have put a new water pump new head gasket and thermostat it the car along with a new rad i just dont understand what else it could be
Old 06-26-2006, 10:09 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: cooling problem
You must have a plugged line or something.
95 Talon TSI AWD
97 Eclipse GST
Old 06-26-2006, 10:24 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: cooling problem
You have checked the thermostat right? I just replaced mine. My car would overheat after driving it for less than 5 minutes. The fluid would all shoot out into the overflow bottle. Then when my car would cool down it would get sucked back in. If you haven't checked the thermostat it might be a good idea. They are like 11 dollars. Be positive there is enough coolant too.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 06-27-2006, 07:03 PM
SLoe's Avatar
SLoe SLoe is offline
Re: cooling problem
You replaced the radiator cap right?? If it isn't sealing, and holding pressure where else would the fluid go but the overflow.......
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
