Turn Signal Two Speeds
My left turn signal flashes at normal speed. My right flashes at twice the speed. ALL TURN, RUNNING, PARKING, BRAKE AND TURN SIGNAL LIGHTS WORKS ON THE RIGHT SIDE. Does anybody have any ideas what would cause this?
Re: Turn Signal Two Speeds
Pull blubs one at a time and see if just one bulb is giving the problem.
I just had the same problem mysteriously correct itself...I figured it was the flasher module at the time since it's always been horrendously loud but I didn't get around to swapping it out before the issue went away.
Oddly enough, my 2000 Blazer is doing the exact same thing. normal on left, fast on right and all lights work. It has been doing it for months. Since the lights work I just left it alone.
Bye Bye Blazer! http://www.cardomain.com/ride/2159611 Hello Monte Carlo! http://www.cardomain.com/ride/2445379 |
It does this to say a bulb is blown.
1995 Factory Blazer Service Manual for sale, PM if interested. |
So what would cause it to happen when all the bulbs are okay?
You sure you tested the brake light operation as well.
One filament in a dual filament bulb is all it will take. The side that is blinking fast is the side with a bulb partially out.
BlazerLt is correct with his diagnosis. If in dought, change all the bulbs on the side that is flashing faster. That is why GM design it, so you know when a bulb is bad or the socket is bad. Also the filament change be blown near the post it is connected and when sitting still, it can make a connection and work, but when your driving it no longer makes a connection.
SC |
Switched brake light bulbs in back. Right bulb was bad. Replaced it and all is well. Thanks for your help.
