Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-26-2006, 03:26 PM
TCossuto TCossuto is offline
Break hissing sound?
When I hold the break at a stop, it makes a hissing sound. I'm not to framiler with mercurys or breaks, so what could it be? I assume the breaks are presurized, so maybe a leak? Is there a common place for them to leak, kinda sounds like above the pedal but i didnt see anything.
Thanks
Tom
Old 06-26-2006, 11:19 PM
vtwindave vtwindave is offline
Re: Break hissing sound?
sounds like the brake booster is leaking, does the pedal fell hard when you step on it? the brake booster is the black round canister that the master cylinder mounts to, it has a vaccum line attached to it.
Old 06-27-2006, 01:33 AM
The breaks feel extremly light. If i push down like half an inch, it almost comes to a stop from 45mph. is that normal?
Old 06-27-2006, 03:11 AM
dzus dzus is offline
B-R-A-K-E.....brake,like on a car.
B-R-E-A-K.....break,like I'm on a coffee break.
Old 06-27-2006, 11:30 PM
sounds like the brakes are working fine. the brake booster is a vaccum canister, when you step on the brakes the vaccum "assists" the force needed to apply the breaks. the hissing is probably air being sucked in around the plunger that pushes on the vaccum booster. if your pedal gets hard to push to stop then you'll need to replace the booster.
