Old 08-06-2002, 01:21 AM
4thgenhb 4thgenhb is offline
Question sticky pedal
1st, i'm new to the forum & i wanted to say whadup to everyone... i was looking for 4th gen sites & this is the 1st i found. i live in va, & i have a manual 4-speed 89 base model hatch. i was wondering if you guys could help me out? the problem is my pedals gets stuck, a lot. i keep needing to stick my foot under the accelerator pedal & pull it up so it will stop reving. when it gets stuck it sounds like it's at around 3 to 5 rpm's. i don't have a rpm gauge so that's why i said, "it sounds like". i've been told it might be the throttle body. but i haven't got it looked at yet. any comments/advice?
THANKS
4thgenhb
Old 08-06-2002, 06:24 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Hey! Welcome to the board. Trust me, it's a gold-mine of knowledge and support.
Sorry, I haven't encountered that problem before, so I can't really help other than to say try some WD-40 or something on the pedal pivot points? Is it just your accellerator, or the clutch and brake as well?
Old 08-07-2002, 04:36 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
the other thing you may want to check/replace is the throttle cable
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-07-2002, 07:55 PM
civicf/x civicf/x is offline
sticky pedal
I've had the exact same problem. Man on both of my civics. On my old one I tried using wd40 on the throttle body as well as carb cleaner. Neither really worked. I also got a cable from the wrecker, that was a bad idea. Just go to honda and get a new cable it fixed the problem on my new civic no problem, and its probably only about 20.00 to fix.
Old 08-08-2002, 12:38 AM
re: sticky pedal
ci5ic... it's just my accel. pedal that gets stuck
civicf/x... will it be worth it if i get a performance thorttle cable??? or should i just go ahead & get a honda one???
Melt... thanks for the advice too
---> 4thgenhb
Old 08-08-2002, 01:03 AM
ci5ic's Avatar
Just go with the honda one... I can't think of anything that would cause a throttle cable to be reffered to as a "performance throttle cable" other than a higher price-tag.
2000 Sonoma Gas Pedal on floor but no acceleration timaugie Sonoma | S-15 0 07-29-2009 03:25 AM
Installing a clutch pedal assembly towelie Ranger | Courier 1 02-15-2009 08:18 PM
Sticky pedal stinkyone Jimmy 4 06-27-2006 09:11 PM
Sticky Pedal igkyoa Malibu 0 06-10-2005 02:15 AM
