Old 06-26-2006, 07:39 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Striping Enamel Paints
What is the best and safest thing to use to strip Enamel Paint from Pastic parts. I bought a kit very cheaply and a few small parts were already started.
I looks like enamel paints and being the UK most probably Humbrol brand.
Thanks in advance
Steve a.k.a. Hiroboy
Old 06-26-2006, 07:48 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Striping Enamel Paints
Can you get Simple Green in the UK?
It's my latest favorite safe stripper, for acrylics, enamels, and automotive laquers. Failing that, CSC type cleaner is excellent for enamels. The enamel on my Z3 was thick and six years old when I stripped it in CSC- came clean in a day of soaking. Then of course there's isopropyl, but I understand it's hard to get in the UK....
So, what's the kit?
PHOTOBUCKET SUCKS
Old 06-26-2006, 07:59 AM
M1CRO M1CRO is offline
Send a message via MSN to M1CRO
I was gonna ask something along this line too steve. I have a 959 painted with tamiya silver then sealed with a halfords laquer. I have tried the oven cleaners and the heavy degreasers as suggesed but they wont remove the halfords laquer,which will then allow me to remove the tamiya paint with something less potent. Maybe the halfords laquer has more of a enamel type property?
I know that nitromorse is one of the stronger paintstrippers but Im not sure if it would waste the plastic too.
Dont wanna risk it to be honest
M1CRO.
Old 06-26-2006, 08:04 AM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
You can either use a product called "Modelstrip" or alternatively you can use "Mr.Muscle oven cleaner" make sure you use gloves with the oven cleaner and do it outside, PHEW! it stinks to high heaven. Put the parts in a strong plastic bag and spray them with the oven cleaner, seal the bag up and leave it for a couple of hours, scrub them with an old toothbrush under COLD water and the paint should come straight off, if there are any bits left with paint on repeat the process until they are clean, dry and paint as normal. Sorted!
Shaun.
MY 1:1 toy
Old 06-26-2006, 08:14 AM
klutz_100's Avatar
Steve, simple green is my favorite now, too (although its HUGELY expensive here ) Takes off enamels OK. 250GTO painted with Humbrol is now bare plastic again
I'm pretty sure I saw it advertised in UK.
I need to work out how much dilution it will take and still strip to make it cheaper for me to use.
Old 06-26-2006, 09:35 AM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
brake fluid will strip anything enamels, laquers, and acrylics, how ever i have noticed that the the brake down of the paint will happen much faster if you spray a coat of laquer paint on it then put it in brake fluid, i think this happens because the laquer has hot chemicals, and then the brake fluid will raise the heat even more, making it much faster to strip
Old 06-26-2006, 09:55 AM
cyberkid's Avatar
cyberkid cyberkid is offline
If that really is what happens then I wouldn't wanna try it... think about it... brake fluid already can make models brittle and warp them. If you make it even hotter... won't the plastic actually MELT? You have better control when things go slow, so why risk it?
Just my .
Steve
Old 06-26-2006, 10:13 AM
Hiroboy's Avatar
Just found some Isopropyl, I asked my Post Office lady who is a St. John Ambulance, volunteer, and she pointed me to a small Independent Chemist.
I now have 2 litres
Thanks Guys
Old 06-26-2006, 10:33 AM
Hiroboy's Avatar
Isopropyl Alcohol
Having done a bit of research now I have some. I contacted the manufacturer
And being a Trade customer I could supply stock this and supply in the UK.
As it's a Hazardous Product I can only supply within the UK
Anyone interested ?
Old 06-26-2006, 10:51 AM
klutz_100's Avatar
Originally Posted by Hiroboy
Isopropyl Alcohol
Anyone interested ?
Very! But shaken only, please. Not stirred.
Old 06-26-2006, 04:26 PM
Isopropyl Alcohol
Anyone interested ?
If thats a practical suggestion steve then I would definately be purchasing some from you.Maybe you could add It as an item?
M1CRO.
