Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-25-2006, 07:52 PM
rustyrun rustyrun is offline
1995 auto shifter lock
Something went awry in my automatic shift lever whereas I have to push the detent down with a scredriver to unlock the shifter every time. Can anybody tell me what part goes bad? I took off the console and jury rigged it so I can shift for now but cannot see what is wrong because all the plastic parts are intact. I see there is an electrical switch.
Old 07-01-2006, 04:53 PM
KimMG KimMG is offline
AF - Advisor
Re: 1995 auto shifter lock
Check to see if the brake pedal switch is working.
Old 07-05-2006, 08:01 PM
Den3221 Den3221 is offline
I have a 1999 that just started doing the same thing.
Have you figured out what the problem is? What/where is the brake pedal switch?
I also just recently (about the same time) started having problems with my cruise control. When I click it 'on' the "cruise control" light just flickers on the dashboard. Any ideas??
Thanks
Old 07-13-2006, 12:54 PM
RustyRun,
Did you ever find/fix the problem?
I am having a similar problem with my 99 and want to try and fix it this weekend. I am also having problems with my cruise control. From what I read, it sounds like it is the brake light switch, but wanted to see if you had any luck.
Anyone else have any ideas?
Thanks, Dennis
Old 07-14-2006, 01:33 AM
4RUNNER_RIDER 4RUNNER_RIDER is offline
There is a spring that hold the thing that I forgot what you call it is maybe break or loose, that's why you always have to use a screw driver to shift it so to open the thing, you need to remove the coloumn, check the FSM for the direction to it. Simple Job! 4runner rider.
