Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-25-2006, 01:45 PM
mattd424 mattd424 is offline
vaccum line
ok i need sum help plz.lol.im trying to find a part name and number.this is a 95 bonn 3.8 the vaccum connection broke at the engine 1 line is connected to the brake booster then the smaller line goes to firewall connectors te piece that broke sits in the engine back side of it looks as if it clips into place.breake booster line plugs into back of it then the line i assume to be accessory plugs onto top fitting broke right there.thank you
Old 06-26-2006, 12:44 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: vaccum line
The GM part number is 24506013, and it is called a vacuum SCE manifold. It is mounted in the back of the upper plenum, about in the middle, on the 3800 vin-k. If it's a supercharged 3800, it is part# 24501530 and is mounted toward the drivers side, near the throttle body if the GM picture is accurate.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-01-2006, 03:19 PM
Re: vaccum line
thank you very much ive had it taped up till i can get a new 1 the car was starting shake suckin all that air thanks agin
