Old 06-25-2006, 10:34 AM
madjeygirl madjeygirl is offline
95 blazer wont start
we own a 1995 4dr 4x4 , with a vortec4.3 cpi,
blew the head gasket, got the heads checked all good, all new gaskets, new filter etc, put it all back together and now it wont start. it will turn over but will not start.
the fuel pump is working,
the is no spark at the coil
battery charged? yes
engine cranking speed sufficent? yes
over half a tank of gas yes
OBD system check.. No
i dont believe that the injectors are working,
checked wires, no pulse at all getting to the coil,
no pulse getting to the injectors.
coil checked out fine.
any help would be great, suggestion, a match what ever.. thanks!
Lil Red 4x4
Old 06-25-2006, 11:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 blazer wont start
First thing we need to know if it is a PCM computer behind glove box or a VCM with the later ign system.
A vcm computer will be on the right fender under water tank.
Let us know which one it is.
Check all fuses and make sure everything is pluged in and hooked up good.
Then go for 12 volts getting to the coil.
MT
MT
Old 06-25-2006, 11:43 AM
MT-2500's Avatar
AF - Advisor
If equiped with the VCM computer system .
Here is the first test.
MT
ENHANCED/HIGH VALUE IGNITION SYSTEM (080-11)
NOTE: This system is used on "S" and "T" Series with 4.3L engine equipped with VCM-A controller. Timing is not adjustable on this system.
Spark
1) If equipped with factory tachometer, disconnect tachometer terminal before performing tests. To disconnect tachometer lead, it is necessary to disconnect the Gray ignition coil connector from ignition coil. Using a fused jumper wire, jumper connector terminal"B" of ignition coil and Terminal Test Adapter Kit (J 35616-A).
2) Using Spark Tester (ST -125), crank engine and check for spark at coil wire and at each spark plug wire. If spark is not
present or intermittent, go to next step. If spark is present, check spark plugs and fuel system.
3) Check coil wire or spark plug wire resistance on suspect wire. Resistance should be about 1000 ohms per inch.
Ignition Coil Power Source
1) Turn ignition off. Disconnect ignition coil driver module connector. Turn ignition on. Using DVOM, check voltage at ignition coil driver module terminals "A" and "0". See Fig. 5. Both terminals should read 10 volts or greater. If voltage is as specified on both terminals, go to next step. If voltage is 10 volts or less on either or both terminals, go to step 6).
2) Place DVOM on AC scale. Connect DVOM to ignition coil module terminal "B" and ground. Crank engine. Voltage reading should be 1-4 volts. If voltage reading is as specified, go to next step. If voltage reading is not as specified, go to step 4).
3) Connect test light to battery voltage and probe coil
driver module connector terminal "C". See Fig. 5. If test light illuminates, check for faulty ignition coil driver module connection or faulty ignition coil module. If test light does not illuminate, check for open ignition coil driver module ground.
4) Turn ignition off. Disconnect Gray VCM-A harness
connector. Check for continuity between VCM-A ignition control connector terminal and ignition driver module connector terminal "B". If continuity is present, go to next step. If continuity is not
present, check for open IC circuit between VCM-A and ignition coil driver module.
5) Connect test light to battery voltage and probe VCM-A ignition control harness terminal. If test light illuminates, check
for grounded IC circuit between VCM-A and ignition coil driver module. If test light does not illuminate, check for faulty VCM-A connection or VCM-A.
6) If voltage is less than 10 volts on both terminals, check for faulty ignition feed circuit to ignition coil, grounded external coil circuit or faulty ignition coil. If voltage is less than 10 volts
on only one of the terminals, check circuit from affected terminal or check for faulty coil connection or faulty coil.
MT
Old 06-25-2006, 06:47 PM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Try too see if it's your security system. The anti theft system will keep the coil and the injectors from firing.
SC
Old 06-25-2006, 09:44 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
No spark at the coil would probably mean you have a bad coil.
1995 Factory Blazer Service Manual for sale, PM if interested.
