Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 08-19-2001, 12:50 PM
zykotik zykotik is offline
Send a message via ICQ to zykotik Send a message via AIM to zykotik Send a message via Yahoo to zykotik
Symptoms leading to starter failure
Can anyone tell me what these are?
I have to push my car to start it effective RIGHT NOW..not sure if its my homemade neutral switch (from my conversion) or the starter.
-Objects in mirror are losing-
www.npclub.com
Old 08-19-2001, 08:11 PM
1PNYBOY 1PNYBOY is offline
By reading your first thread (double thread), it sounds like you have a starter going bad. I have seen more than a few G's with bad starter's after the get a little ge on them. If the car does not not start in nuetral then that's a good sign that the starter's going bad. Also, if when it doesn't start, you have power throughout the vehicle(i.e. power windows work, radio works, lights work, etc.), than that is alos a good sign that the starter is bad.
2002 G20 w/sport package.
1993 Mustang coupe 5.0(of course) with Vortech and too much to list.
Service Advisor for Infiniti
Old 08-19-2001, 10:02 PM
So then it is not impossible for a bad starter that stopped working to start working again?
www.npclub.com
Old 08-19-2001, 10:50 PM
flipg20 flipg20 is offline
Send a message via AIM to flipg20 Send a message via Yahoo to flipg20
Its possible for a starter to start again even if its acting like that because I had the same problem.
Old 08-20-2001, 06:16 AM
Ok and it was you starter flip?
www.npclub.com
Old 08-20-2001, 03:45 PM
yup it was the starter.
Old 08-20-2001, 04:35 PM
primera man's Avatar
"P-Man"
If you tap the outside of it with a hammer it can help if the starter is just clicking when you turn the key. Sometimes they jam in a place on there teeth and wont move in to the flywheel to turn the engine
View All My Models Here.
Old 08-20-2001, 06:38 PM
Rebuilt my starter this morning..no more problems...Also I found ou that my battery was weak too.
www.npclub.com
Does my 1973 MGB require LEAD or NO-LEAD? hooverbean MGB 1 06-19-2010 05:45 AM
re-attach defog lead? zoniguana Taurus | Taurus Wagon 4 10-16-2009 06:58 AM
Starter Failure? snewganz Lumina 3 12-26-2005 07:18 PM
Starter failures 1534dover Park Avenue 1 07-02-2005 01:55 PM
