Handling Question
The alignment is off. The wheel is very loose. Let's say I'm making a left turn, I turn the wheel, the power steering is working but then the wheel reaches it's limit against the chassis, it makes a buzzing noise and I make a VERY wide turn.
If I replace the steering components, will my steering get better than it is? Does being lowered have anything do with it?
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD Last edited by Dyno247365; 06-26-2006 at 05:17 PM. |
Re: Handling Question
better? I need expertise here
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
Also, in yet another thread again, you started up something about your ride height, if the ride height has been altered from stock, but all other angles of the steering and suspension have not been adjusted to compensate for this, that in itself will have an impact. If you still just feel like shotgunning parts at it, common failures are the rods in and out, center link, pitman and idler bushings. |
If memory servs correct this car has had collison damage..........
Pitman arm and shaft may be twisted from the impact |
