Roaring Noise
I have a 96 VR4 that I just bought that makes a roaring noise when I am driving it even at slow speeds. It sounds like road noise from the tires. I had a 97 SL about a year back and I don't remember it making that much noise. The VR4 has only 9300 miles and still has the original Yokohama tires. It was driven enough so that there doesn't seem to be any flat spots on the tires. Also, I am sure that that this is the actual miles for the car. Is it normal for the VR4's to have this loud tire roar? Also, I know this is a sports car but, the ride is horrible. Again, the 3000SL had a much better ride. I know that the VR4's suspension is a little firmer but, I was riding on a concrete highway and I was bouncing up and down in my seat in rhythm to the joint strips. I was hoping to take the VR4 on a long road trip but not with the way it rides. Again, I Know it’s a Sports Car but, the ride and noise seem a little rough even for this segment. Maybe I should look for a 97 with the dual mode suspension. Any ideas to improve the ride or lessen the road noise? Thanks.
Re: Roaring Noise
suspension upgrade....and take it to a trusted mechanic? thats pretty basic and just go from there
1991 Pearl White Mitsubishi 3000GT SL
Re: Roaring Noise
Noise is probably the tires with only 9300 miles, the ride is supposed to be rough, it's not meant for long trips, it's meant for performance, you're supposed to feel every bump. Make sure the front end is tight (wheel bearings, tie rods, ball joints), if so, change the tires to a quieter type if it bothers you that much. If you don't want to feel the bumps, get softer struts, you'll just take a decrease in handling.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Re: Roaring Noise
Re: Roaring Noise
Nope don't have it on this one....had it on my SL...but I doubt the ECS is the same between VR4/SL so I couldn't say.
I thought the same thing when I bought mine, the 5 hour drive back from NJ started gettin to me in about that last hour...I was like "these roads SUCK! too many freakin bumps!!". But I got used to it, doesn't bug me at all now.
Re: Roaring Noise
possibly the previous owner got aftermarket struts and didnt tell you? I dont know if theres a difference between 93 VR4 and 96 VR4 suspension, but even in sports mode my ride still sounds better than what your describing, and im in upstate NY (super shitty roads).
Anyways, since the car is meant as a grand tourer, it is supposed to be fairly comfortable for longer trips. Also, if the car is "bouncing" as you said, you probably have warn out struts. But with less than 10K on the car, thats really not possible. although maybe your just not used to the ride. Did you have a luxury car before you bought the VR4? lol Not sure about the road noise though...tires wearing evenly? GL man |
Re: Roaring Noise
I wish I knew someone around here who has a VR4 so I could compare. I live in NC near Danville, Va. If anyone reads this who has a VR4 nearby, I'd like to talk to you about letting me ride in yours just as a comparison. I mean the ride is so bad in mine, I am tempted to sell the car and go back to an SL if it can't be improved. As to my cars that I have had before; yeah, I am driving a 2002 Diamante. It has a firm but comfortable ride. However, I had a 97 3000GL and the ride on that was fine. By the way, are the front rims/tires on your car smaller in front or is that just the camera perspective. Asking because I understand from the manual that front and back need to be the same size on the 4wd. Thanks again. |
Re: Roaring Noise
Yes the tires should/need to be the same size. There are a few exceptions, but for general arguments sake, let's stick with yes they need to be the same for now.
Back on topic. I feel every freaking thing in my car, remember you have 18in rims with low profile sport tires...this means the car's 'footprint' is freaking huge...ride comfort was not the main idea. Tight sport suspension doesn't help. Any rough roads drive me nuts and send my car bouncing all over, but on plain well paved roads it really doesn't bother me at all. And tire noise has always been minimal for me. If you are really worried, I'd check out the tire pressure, check the tires for flat spots, and make sure nothing is rubbing anywhere.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Roaring Noise
just camera angle. wheels and tires are identical.
Re: Roaring Noise
When my 92 TT starting "roaring" I thought it was the tires..turned out to be a rear axle bearing that gave out 200 miles from home..sounded just like tire/road noise
Re: Roaring Noise
Re: Roaring Noise
Re: Roaring Noise
Re: Roaring Noise
if its a bearing, then there will be a noticable hum/roar only at a certain speed.
i replaced my rear passenger side bearing b/c i had a hum at 65-70mph. it was pretty constant. i asked a mechanic friend, and he suggested the wheel bearing after i concluded it wasn't a problem with the tires. the tricky part might be locating which wheel bearing is making the hum. you'll have to listen closely, but it shouldn't be that difficult.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: Roaring Noise
"Where are we going? and why are we in this handbasket?" |
