Old 06-24-2006, 05:34 PM
Chilean_Dude's Avatar
Chilean_Dude Chilean_Dude is offline
88 Voyager hesitates while accelerating
Hello everyone:
Recently my brand old 1988 Plymouth Voyager (V6 3.0 L Engine) started to hesitate while accelerating and maintaining a steady speed. This usually happens after 10 minutes of driving with the engine warm. The Tachometer shoots up and down. I step on the gas, but it doesn't kick in until the RPMs go down to 1000 or less. The idle speed is between 800/900 RPMs.
The first things I've changed are:
  • Spark plugs/cables (it was time to change them anyways)
  • Fuel filter (what I thought to be the problem, but wasn't)
  • Air filter
Now I've changed:
  • Throttle Position Sensor (drove just fine for a lil' while, then hesitation came back again)
Gonna change tomorrow:
  • Oxygen Sensor (I believe it's never been changed)
  • PCV valve (Should it always make a little rattle when the engine is on? or should it rattle and stop now and then?)
I did the on, off, on, off, on ignition thing to check the codes and I get:
code 24 -Throttle Position sensor voltage low/high
code 36 - Wastegate control circuit open or shorted (turbo only)
If the TPS voltage is too low/high, what would cause/fix this problem?
What else could be causing the hesitation?
Thanks!...
Any feedback will be appreciated...
