Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-24-2006, 05:31 PM
MrLeftLane MrLeftLane is offline
Send a message via AIM to MrLeftLane
Wiring Halos
Im new to this forum and i need some help.....I am 16 years old and my dad told me i can have this neon 95 dodge neon to fix up and he'll give me the $$ i need and if i dont like it then i can sell it. Anyway top get to the point i need help with wiring my new headlights i got tthey are halos and they didnt come with a wiring diagram so if anyone could help me out plz and thank you!!!!
Old 06-25-2006, 09:16 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Wiring Halos
They're not plug and play?
Old 06-25-2006, 10:01 AM
Re: Wiring Halos
they are but the halos havew 2 extra wires just for the Halo i think im goin to have to get a toggle switch and put the wires got off the battery and then through the firewall
Old 06-25-2006, 01:14 PM
Wollf's Avatar
Wollf Wollf is offline
Re: Wiring Halos
You can use a spare fuse outlet from your fuse panel , i had a few , ground out the black and run the red through your firewall. Place a switch inline and then continue it into your fuse box , you can run a low amperage fuse that way as well , or if you dont want to go that far you can tap a power from one of your other fuses... like radio or interior lights.
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Old 06-25-2006, 02:55 PM
HPNOTIQracing HPNOTIQracing is offline
Re: Wiring Halos
im pretty sure they are made to tap into your marker lights so that you can have them on seperate from your headlights.
one wire on each side is a ground and one on each side is a power. ground each one to the body behind the light and run each power wire to a hot in your marker lights wiring.
Old 06-25-2006, 04:38 PM
Re: Wiring Halos
Sounds simple, yet effective.
