Just purchased o1 Blazer. Gas gauge acts erratic. sometimes registers right other shows empty and low fuel light on. This happens sometimes while idling other times it can do it anytime. Any suggestions
Re: 01 gas gauge
sending unit probably......... do a search lots of info on this
92 S10 Blazer Sport 4.3l Vortec V6 (W) 275,000 miles Jasper engine, Rebuilt tranny + rearend 04 Pontiac Grand Prix GT 43,000 miles |
Re: 01 gas gauge
Yep, my 01 4wd 4dr has that too and the 1 piece pump sender is $300 Delco #MU-85 so look up at rockauto and click on the more info by the pump and see a pic of the redesined model. 2 door and 4 door are diff.
Re: 01 gas gauge
2000 Blazer 4WD 2Door http://www.cardomain.com/ride/2324297 06 Pontiac G6 V6 Coupe http://www.cardomain.com/ride/2371527 |
Re: 01 gas gauge
Your sending unit is definately bad. I don't think you can purchase just the sending unit. You'll have to buy the fuel pump assembly. As far as it damaging your fuel pump, it will not damage it. The sending unit is only used for determine the amount of fuel it your tank. However, if your truck has 75K to 100k miles on it, replace the fuel pump anyway. It will go out on you somewhere around those miles. You can thump the botton of the tank with a rubber hammer and make it work for a while. Maybe just long enouth to get it home. The brushes in the fuel pump motor go bad and that's what happens to the fuel pump.
SC |
