Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 06-24-2006, 02:40 PM
Decipha Decipha is offline
a/c vac pump
i have a spx robinair 6 cfm vac pump it looks like it has 1 connection which im assuming is for the low pressure side, if i run a vac do i just connect the low vac side to the low pressure side and run a vac at 29 microns???
i checked the pressure at my low pressure side and it didnt show up on the gauge, the a/c hasnt worked since i owned the vehicle but its damn hot here in new orleans... help plz any advice is greatly appreciated
sry mods i'll try 2 b good
Old 06-24-2006, 08:35 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Re: a/c vac pump
That one connection would be for connection to a manifold gauge set and then connecting to the vehicle.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 06-24-2006, 09:15 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: a/c vac pump
Hook your gauges to the car. And as said hook the vacume pump to the middle port on gauge manifold.
With vacume pump running open the valves on the gauges and you should start to see vacume on gauges and your system.
Be sure to close your valves on the gauges before turning vacume pump off or you will lose your vacume on system.
If the system has not been working or open for a while a good long vacume pull down of 4-6 hrs or longer helps.
MT
MT
