Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-24-2006, 01:35 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
CEL P0170 Fuel Trim Malfunction
This cell popped up the other night when I was just normall driving. I had ran it hard earlier that night but, at the moment it came on I was daily driving. This cell came up once before. I would just like to know if anyone call tell me some details on this cell. It reads P0170 - Fuel Trim Malfunction (Bank 1)
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 06-24-2006, 04:16 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: CEL P0170 Fuel Trim Malfunction
Fuel trim is maxed out in one direction or the other, and the ECU still wants to adjust it further.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-24-2006, 11:00 PM
NateS's Avatar
Ah thanks. Is this probably due to the 650 injectors and using the afc to tune?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 06-25-2006, 03:57 AM
AF - Advisor
What are your low settings on the AFC?
Kevin Jewer
Old 06-26-2006, 09:27 PM
NateS's Avatar
The low throttle is set at -30% up till 3k then it goes to -31%
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 06-28-2006, 06:23 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
My car just threw the same code. I've been trying to figure out what it means. I have 450cc injectors set to 32psi at idle. Runs rich as crap but its the best I can do until I get a piggy back. So I guess what this code is telling me is that the ECU isn't capable of leaning out the mixture far enough? Is this right?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 06-28-2006, 09:53 PM
AF - Advisor
You're fuel psressure is 32 psi? If so, the ECU is not trying to lean out, but add fuel
The AFC settings above seem right on, so no smoking gun there.
Kevin Jewer
Old 06-29-2006, 03:39 PM
But my car is non turbo.....wow, this is confusing.
Caleb
vanilla gorilla
Old 06-29-2006, 08:52 PM
AF - Advisor
Shit, I have no idea what a NT FP should be. Still seems it would need to be higher. Injectors are rated at 43 psi typically, and manufactures usually stay within 5 psi or so.
Kevin Jewer
Old 06-29-2006, 10:03 PM
Well, see the car came with 275cc and I swapped them for 450cc in preparation for turbo. 32psi was as low as I could get my FP. The car is obviously running pretty rich which I guess is due to the over sized injectors and not having the compensating airflow from the yet to be installed turbo system. So my guess at why I was getting the code is that I figure the ECU has leaned the system out as far as it can which still isn't enough. Does that makes sense? lol. I need to hurry up and get my piggy back and finish getting all my turbo parts so I can install them and get this beast running right.
Caleb
vanilla gorilla
Old 06-29-2006, 10:06 PM
AF - Advisor
That does make more sense. Can't expect to run the "wrong" injectors and not get a fuel trim CEL!
Just for fun, because I'm a sick, sick man, and this is fun for me, you would need to lower fuel pressure to 16 psi to make 450s flow like 275s.
Edit> More fun... At 32 psi your injectors flow like 388s. They are still 30% too big. The ECU does not have that much range. A 2g turbo ECU (not sure about NT) can adjust LTFTs up to 12.5%, and STFT up to either 12 or 16%. Not enough to cover a 30% discrepancy. So the CEL certainly makes sense.
See, isn't this fun?
Kevin Jewer
Old 06-29-2006, 11:06 PM
Wow. Your just too good.
Caleb
vanilla gorilla
Old 06-29-2006, 11:21 PM
NateS's Avatar
Lol yes he is. Oh, and I have popped this cell 2 more times since I have posted this. Infact my car sits in my driveway with this code again. It seems to come on when I am daily driving which is wierd too. Not like I'm at WOT on the interstate running from the cops when this thing comes on. Probably like under 40mph and like 30% or so throttle. I'm not too worried about this issue because, I am almost positive it is running too rich. I'd rather be rich than lean untill I get dsmlink.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
