Old 08-05-2002, 01:18 PM
bobbyd bobbyd is offline
how to install tach?
i want a tach for my 90 hatchback and was wondering how hard they are to install? thanks fellas.
"Are you gonna bark all day little doggy, or are you gonna bite?"
Old 08-05-2002, 01:35 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Thumbs up
Hey bobbyd...
There are a few ways to install a tach...1) Get a cluster for your year Civic from a junkyard with a tach..The wiring is already there to support one....or 2) buy an aftermarket tach.
I installed an aftermarket tach..Typical tachs have 4 wires....
red - connect to 12v (i.e. - to ignition, power to make the unit function)
white - light, connect to dash lights or similar
black - ground, connect to a good ground source
green - tach signal, I connected mine under the hood right next to teh distributor, however, the same blue wire should be inside your instrument cluster if you don't wanna go thru the firewall. Here is a pic of my connection...the green wire is from the tach.....and I connected it to the blue wire with a fold-over crimp type connector..I filled the connector with silicone prior to the fold/crimp to prevent corrosion.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-05-2002, 01:49 PM
thanks shawn!!!
that will do great. i am goign to print this out. hopefully i can get a cheap summit racing tach soon.
Old 08-05-2002, 04:07 PM
sastanley's Avatar
AF Premium User
Smile Pick a theme early to be coordinated later !
Autometer makes pretty good gauges and Summit sells them...You may want to think about picking a style you like so if you choose to add more gauges later, they'll match up with ones you bought before..
I bought a little SunPro tach, and it works great, but doesn't match the new Autometer gauges I bought to go with my ZC engine when I put it in...so if I wanna be stylin' and coordinated, I have to replace the tach.
I am 99% sure I got the wires right, but any tach should have complete instructions..the thing that is confusing is usually the signal wire (green on my tach), and which wire to hook it to on your car.
Good luck..Shawn
Old 08-05-2002, 05:51 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Hey Shawn,
I was curious about what kind of silicone you put inside that crimp connector? Also, is that the same stuff that they put on the turn-signal and parking light connectors?
Mike
Old 08-05-2002, 06:26 PM
sackerius's Avatar
sackerius sackerius is offline
hey, thats weird lol, i installed mine IDENTICLY... same color wire and everytthing... i duno i love my tach tho, indiglo at night, white face... and its on the A-pillar... which is definetally a cool thing i say... but ya i wont keep u all caught up in my words, cuz i dont have any pics yet! but ya, ill ttyl
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 11:04 PM
How To Install Tach In Coilpack zeus999 Off-Topic 2 09-15-2005 09:49 PM
1987 Honda CRX Si how to install tach sjhb76 How-To's and Walk-Through's 1 06-27-2005 03:01 PM
Installing Tach on a '91 Automatic? kooki3 S-10 0 07-28-2004 05:35 PM
install tach ssaiyanman Automotive News Desk 0 06-21-2004 10:36 AM
