i plan on buying a set of 6-1/2" polk speakers( for the front door panels)
![]() now looking at these im seeing 2 mids and 2 tweeter and I would need to drill a hole for the tweeters right???? also I plan on getting the kick panel boxes to hold another set of 5-1/4" Components up front would this be to much???(4 mids plus 4 tweeters up front)??? or should i just upgrade my stocks and leave it at that??? the speakers in my truck are going to be powered by a 4ch 800 watt power acoustik amps 2ohm 85watts max each ch. or 4ohm 70watts max each ch. for bass im going to use 2 Ma audio subs 500 watts max each powered with a 1000 watt max kenwood amp Thank for your input
Simon R 2001 Silverado W/T 4.3 124,000 |
Re: speakers again
I think it depends on your stock trim level. My door panel already has two holes, one for a tweeter, but I know they all don't. I just never paid attention to which trucks did or didn't.
![]() 2002 5.3l - Quadrasteer
![]() lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner loose (lüs): adj - not rigidly fastened or securely attached |
Re: speakers again
mine is a work truck so I only have 4 speakers 2 front 2 rear I would need to drill the tweeter is small so I dont mind
Re: speakers again
I was wondering how hard is it to install speakers ? Any re-wiring ? I blew my passager side speakers some how, guess i shouldn't listen to music that loud, oh well..How long do you think it would take ?
Re: speakers again
not long at all
Re: speakers again
2002 CHEVY SILVERADO more pics at http://www.cardomain.com/ride/2228127 ![]() ![]() ![]() ![]() more pics at http://www.cardomain.com/ride/2228127 |
Re: speakers again
yea your setup is great man I had no idea you had coax speakers it looks more like you have components but you say they have crossovers are they built in???? I have done some research and i keep hearing components are better whats your opinion???? by the way the amp im using has crossovers as well
Re: speakers again
they are basically components but the tweeters are mounted to the speaker, but they swivel. the crossovers are separate from the speakers like components. but how low your speakers are going to be in the door i would do components just so you get the tweeter up a little higher and get some better sound.
Re: speakers again
