Old 06-23-2006, 11:06 PM
batman3390 batman3390 is offline
no sanding
is there a case where no sanding is necessary. For example, I have a car which appears to have no mold lines. If i lay down perfect coats of paint and avoid orange peel, is sanding necessary? I have Tamiya sppray paint by the way.
Old 06-23-2006, 11:08 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: no sanding
you're going to want to sand the plastic so the paint has something to adhere to.
I always sand my final coat (clear coat) even if it looks smooth, i always sand and polish it out.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-23-2006, 11:46 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: no sanding
i) please use the search feature
ii) please refer to the faq.
iii) IF you have a moldlineless model and IF you lay down perfect paint and IF you have no orange peel, then sure, you won't need to sand.....
AF's Guidelines
Read them.
Old 06-24-2006, 05:25 AM
RallyRaider's Avatar
Zomby Woof
Re: no sanding
Who makes that kit? I've never seen such a beast.
Old 06-24-2006, 05:44 AM
brettly brettly is offline
Re: no sanding
..you sure you havnt looked at it under direct light?
Old 06-24-2006, 11:24 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: no sanding
Yes there is. That scenerio is that the person making the model isn't paying enough attention or s/he doesn't care that much on the results. I've been modeling and wood crafting for over a decade. I can't remember one project that didn't need me to put some elbow grease into sanding.
Couple of things though, a lot of poeple sand the whole model down with 800 or 1000 grit sand paper to give the paint more grip. And like pre98zetec said: sanding your last coat before polishing makes it easier to get a nice shine and a smoother surface. Another most common use of sanding is when you cut off a piece of the model from the sprue and you need to clean off the excess sprue.
Old 06-24-2006, 02:32 PM
LS1Aaron LS1Aaron is offline
Re: no sanding
For sure,most kits require little to no prep work and almost always have a flawless finish.Ive even found that brush painting bodies works well,especially with lacquer paints.
Old 06-24-2006, 03:50 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: no sanding
That I want to see.
Old 06-24-2006, 05:56 PM
Re: no sanding
Im joking ,come on now.
