Lumina '99 break problem
hi, my lumina wasn't stoppin' very well, so i thoght that the break pump was broke and i replace it. After install the new pump i still have the same problem. I have to push the pedal to the floor to stop. Somebody plz help me !!!!!!
Re: Lumina '99 break problem
are you losing fluid somewhere? by pump you mean master cylinder, right? the thing under the hood, on the drivers side? If you did replace the master cylinder, did you remember to bleed the whole brake system?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
When I installed the master cylinder I bleed it but the problem still. I'm open to any suggerence, Thanks a lot!!!!!!!!!! |
bleed it again, start with the wheel farthest fron the master cylinder. sometimes they need to be bled like 3 times, and also, i havn't had to do it on my car yet, so im not for sure, but you may need a tech 2 scan tool to command abs valves open if you have abs
Yo blake, thanks for the help buddy!!!!! |
yeah, sometimes the remanufactured ones dont hold pressure either, glag i could help ya out.
