Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-23-2006, 09:24 PM
Destry Destry is offline
Question 83 A/C compressor won't turn on
The problem 1st started with the blower not shutting off and burned up.
Dealer replaced motor and ECC module. Now the compressor won't turn on.
Took it back to the dealer and they replaced the ECC module again, but still the compressor won't turn on. I hot wired the compressor clutch and the a/c workes well. Does anyone know if their is a relay for the clutch somewhere?
If so,where. It seams that all the wires from the ECC module go through the firewall. It also seams that the wire from the compressor clutch also goes through the fire. Any help or ideas.
Old 06-24-2006, 07:12 AM
DFBonnett DFBonnett is offline
Re: 83 A/C compressor won't turn on
Can you put a test light or VOM on the wire going to the clutch and see if it's getting power when the AC is switched on?
Also check the fuses and relays under the hood. On my '93 Eldo they are forward of the driver's side front wheel.
FWIW
YMMV
