Ignition Lock Cylinder
The keys for my 1998 Neon will not longer turn the lock cylinder, she is stuck in off position. How do I get the lock cylinder out as I cannot get her to the run position?
Re: Ignition Lock Cylinder
(1) Disconnect the negative cable from the battery.
(2) Before beginning removal of steering column assembly from vehicle, be sure front wheels of vehicle are in the straight ahead position. (3) Remove the 4 screws attaching steering column cover, to lower instrument panel. Then remove the trim panel from the instrument panel. (4) Remove 3 screws attaching the steering column cover liner to the instrument panel. Remove the liner from the lower instrument panel. (5) If vehicle is equipped with speed control, remove the speed control switches from the steering wheel. If vehicle is not equipped with speed control, remove the trim covers from the sides of the steering wheel. 6) Remove the 2 fasteners, 1 on each side of steering wheel, attaching the air bag module to the steering wheel. (7) Remove air bag module from center of steering wheel. Then disconnect the clock spring electrical lead from the back of the air bag module. (8) Disconnect the wiring lead for the horn switch in the airbag module from the wiring lead coming from the clockspring. (9) Turn the lock cylinder to the off position and remove the key from the lock cylinder. (10) Turn the steering wheel to the left 1/2 a turn (180°) until the steering column lock is engaged. (11) Remove the steering wheel retaining nut, from the steering column shaft (12) Remove steering wheel assembly from steering column shaft using Puller. (13) Remove key lock cylinder from steering column by placing the key lock cylinder in the Run position. Then through the hole in lower shroud, depress lock cylinder retaining tab and remove key lock cylinder. Install is reverse of removal. |
I hear you and can do all you suggest, the problem is that the key will not rotate so I cannot get into the RUN position. How can I remove the lock cylinder if I cannot get to RUN position?
Lock Cylinder is working. I removed trim panels and took a screwdriver handle and tapped (very professional) all around the lock cylinder and evidently something broke loos as the key turns and car starts. I am still going to replace the lock cylinder. Thanks for the responses.
all i did was spray wd 40 into mine lol there was alot of dirt and debris build up in there
Through use of a rubber mallet I was able to get the key lock to turn. I pulled the lock cylinder and cleaned it up, reinserted and same problem so back to the mallet and I pulled the cylinder went to dealer and bought anew one (the parts guy rekeyed, for free). Cost was (drum roll) $105 US. I found some online for $85, but after shipping and rekeying it was not a cost saving. Lock is back in and all is well
Good to hear!
