Help with radio please
I am putting in a new radio. I cant see what wires are witch. I cant even get power to the head unit. All fuses are good. Do I have to have the door shut to make it work. Its a 95 cavalier. two door. I dont know what any of the wires are and i dont have a manual. If somebuddy knows what to do or knows what each wire please let me know. If you have the book and a scanner or a digital camara could you take a picture of the wire diagram in the back of the manual. Email is [email protected] thank you very much
Re: Help with radio please
by putting in a new radio i take it that its an aftermarket headunit? i'm not to sure how you cant see which wires are which. the door doesnt have to be shut for it to work either. did you wire all the wires correctly? because if not then that could be your problem right there.
make sure you have a GM wiring harness to adapt to your deck, all the wires are color coded and pretty easy to match up to any deck. go buy yourself a GM wiring harness and some crimp on connectors, the wires on the new harness should be labeled correctly (via color code and some printed) to what gives u power, accesory, dimmer, pwr antenna, speakers etc. if the process is to complicated bring it to an audio shop and have it done professionally.
you might want to check online for a wiring diagram for the deck as well, if things still dont work out, make sure your crimping the right wires together. |
yeah i mean wiring those damn things couldnt be easier. all you have to do is match up the colors.
does the door have to be closed...??
are you serious? have someone do the installation professionally or do a few days research before your next attempt. WATCH THIS VIDEO!! http://www.crutchfieldadvisor.com/le...all&format=mov
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles] Gone but not forgotten: 1995 Pontiac Grand Prix GTP[sold, 128k miles] 1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles] 1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles] 1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems] 1990 Hyundai Excel GL [died, 220k miles, died] |
yeah they used a ford on that video. it alot easier to install a radio on a ford then a chevy. i mean when it comes to removing the stock headunit. on our cavs we have to take the whole damn dash apart, where on the ford all you have to do is take the radio straight out. took me half the time to do my mustang vs. doing my cavy. but yeah when it comes to the door having to be closed??? lol thats something new.
closing the door doesn't cut power you dumbass.. and if you act like a newbie i'm going to treat you like a newbie. now maybe if you stated that the previous installer screwed it up and gave some details, we wouldn't think you were a fuckin fool. i installed my own shit twice thank you........... of course in an 89, you don't have to remove the whole dash, just the faceplate.
nah you were rude about it so i will be rude to you. dont post if your going to act like you know everything. For the newbie part i have just as many post's as you sir. Do treat this site like shit by calling people noobs or trashing people. If you know everything about cars why are you on here? am i right?
Side note though its crazy we had the exact same number of posts till i posted these two things.
try to tone out the lines, speaker lines should be obvious. turn the ignition into the on position and use a voltage meter to figure out which line is getting power with the car. and turn the car ignition to off to see what line is getting power when the car isnt, now you have the power line and the accesory line.
dimmer isnt to important to find but it can easily be toned out in the wire harness adjacent to your cluster piece, you can also use a toner to find the ground wire. if you dont have a toner use a wiggy or an ohm meter. secondly, find out whoever cut the factory wiring harness out, and smack them repeatedly. |
wow this thread went to hell really quick lol
Well thank you all for the help I think i found the problem though. Best buy sold me a blown cd player. got my old cd player out of my other car and hooked it just fine. So yeah have to try to take that back a day later. Thought it smelled blown when i took it out. Tested it on the battery as well and nothing. Fuse is fine as well. Thank you all agian.
