Old 06-23-2006, 07:06 PM
Mark59 Mark59 is offline
Question 92 dodge caravan cruise control
My van never had cruise, I have purchased the complete in steering wheel contoll, and all wires that go down the steering collum. Under the hood The cruise vaccum pump is all installed. All I need is help from stering wheel to plug in wire harness under dash. Can any one help me in how do I install this.
Thank you,
Mark
Old 06-24-2006, 12:38 PM
coalminer coalminer is offline
Send a message via Yahoo to coalminer
Re: 92 dodge caravan cruise control
Thank you,
Mark
The wires for the cruise are allready in the steering column, the only thing that is different is the clock spring for the airbag, when you remove the airbag, remove the steering wheel, you will see a plastic rotating peice, that is the clock spring, do you have the one that has the wires for the cruise???? If you dont, I have one on a van that I am going to scrap, I will give it to you if you pay for the shipping. I did the same thing you want to do, I installed cruise on a 95, and was shocked at how easy it was to do it, all the wiring is there, just need to install the control unit and buttons.
Old 06-24-2006, 03:42 PM
Thumbs up Re: 92 dodge caravan cruise control
Hello coalminer,
Yes I have the plastic clock ring, all wires to and from it inclusive the buttons. In reading I need to remove the air bag? the clock ring mounts under the air bag?
Thank you for offering the one you have, but I have it already. I'm sure someone else could use it though.
Just how hard is it to install?
Thank you,
Mark
Old 06-24-2006, 09:55 PM
Yes, the airbag and the steering wheel have to come off, when you get to that point, its pretty easy, just make sure that the clock spring and steering wheel are centered when you install it.
Old 06-25-2006, 06:58 AM
Thank you coalminer.
Sounds simple enough, you've been very helpful. I probably won't get to it till the weekend of July Eighth but I'll let you know how it went.
Mark
