Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-23-2006, 04:01 PM
blehman blehman is offline
66 Impala Front Spring Replacement
I am restoring a 66 Impala convertible, doing a frame off restoration. I am in the process of installing the front springs. How should the spring be positioned in the frame seat and lower control arm? There is a hole in the frame just below the upper arm. Should the end of the spring cover this hole or should the hole be open?
I have the 1966 Chassis Service Manual, however, all it states is "Set the spring in place on the crossmember after checking on proper positioning necessary." Any help would be appreciated.
Thanks,
Brian
Old 07-12-2006, 11:50 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: 66 Impala Front Spring Replacement
I've changed a few of these on the old Impalas and never gave that hole any consideration. I believe that it is a tooling hole for the frame fabrication.
The lower end of the spring orients itself on the lower control arm nicely. What is the top of the spring like? I think they had the fully formed coil, which might also locate up in the spring pocket. With the spring out look up and feel the inside of the frame pocket to see if there is a stop of some sort in it.
It might have a hub that the spring has to go over squarely. Use a spring compressor that fits inside the spring itself, watch carefully to make sure that the spring is square in the upper pocket, it will be obviously biased to one side if you miss the locating hub. But the spring is easy to jockey around using a big screwdriver or prybar. You'll have to loosen the compressor a little at a time until the spring seats at the top and you can attach the lower ball joint.
Bob
